Old 09-23-2012, 08:59 PM   #15
SkullV
Originally Posted by ManofManyGTs View Post
There is not enough wire to place it any farther toward the turbo.
That's why they should have placed it in the stock location. Where it is right now is in an area of extremely turbulent air flow with no MAF housing/screening to straighten it out. However with the bend right after the filter the OEM location probably wouldn't be much better (although not a 90*).
Hopefully you don't have any issues but a whole lot of people ditched their forge intakes because of a similar MAF placement.
Old 09-23-2012, 09:09 PM   #16
plac
Guest
Posts: n/a
very nice quality parts, better than i anticipated. kinda sits strange on the engine, but decent fitment.
Old 09-24-2012, 12:47 AM   #17
ManofManyGTs
ManofManyGTs's Avatar
Drives: CSG GTI Autobahn
Originally Posted by oSniper View Post
@ManofManyGTs
by the way you can open up the maf plug part and flip the wire around so it doesn't go the opposite way
Thanks, I'll do that.
I've put maybe 30 miles on the kit today just around town and highway going here and there, multiple stops. So far I have not had any issues with driveability or CELs. What kind of issues were there with the MAF placement on the forge?
Struggling follower of Christ
Mods: Ultimate Racing TBE, CTS Intake, APR Stage II tune
ManofManyGTs is offline   Reply With Quote
Old 09-24-2012, 01:18 AM   #18
ClapperHighs
ClapperHighs's Avatar
Drives: Mk7 GTI RS 6MT / 1983 Porsche 944
So this is an EXACT replica of the BSH intake..? Its the same in every way. I remember a lot of people hating the bsh intake for some reason. Is this supposed to be any different? I have the BSH intake and i have absolutely no complaints with it. I love it.
However i've noticed the tray the filter sits in gets pretty damn hot to the touch after driving for a while. Im sure theres no difference with this one, so thats something to check out if you get a chance. But Im sure it doesn't make much difference at all as regards IAT.
APR Stage 2 : SB stage 3 Drop In : Raceland Downpipe : BSH Race Intake : Coolingmist W/M CMGS : Polar FIS : Pagparts TB Spacer : BSH TB Pipe : Nuespeed TOP : DV Relocation : APR R1 DV : BSH Torque Arm Insert : Unibrace UB : Hotchkis 27mm RSB : 034 RSB End Links : VWR SS : 42DD Shifter Bushings : Verdict Bracket Bushings : Dark Cherry LED Tails : 245 Hankook Evo2's:
ClapperHighs is offline   Reply With Quote
Old 09-24-2012, 02:05 PM   #19
MAD_GTI
MAD_GTI's Avatar
Drives: 2012 CSG GTI
Should be able to edit video, and post up tomorrow.
MAD_GTI is offline   Reply With Quote
Old 09-24-2012, 02:20 PM   #20
ManofManyGTs
I have never seen a BSH in person but from the pictures, I believe they are petty similar. I would not say it is exact though. To my knowledge, the CTS is still a CTS in house developed and built item.
Old 09-24-2012, 02:22 PM   #21
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
FYI, it is the exact same design.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 09-24-2012, 02:26 PM   #22
SkullV
What were the issues people were having with BSH? I remember hearing something about knocking because of bracketry/engine movement, but that's not a huge deal and easily fixed with a little fab work.
Old 09-24-2012, 02:35 PM   #23
plac
Guest
Posts: n/a
if you really want to.. you can find the BSH controversy here.
http://www.golfmkv.com/forums/showthread.php?t=172834
Old 09-24-2012, 02:37 PM   #24
grambles423
Limited Activity
My BSH was crap:
- Uneven welds
- HARD brakeline vibration (even wore away some of the material).
- Bracket to heat shield was cracked with a bad weld.
- Rusting Heat shield
- Heat shield Rubber came off
- Bad silicone connection to turbo
- Bad Clamps
Its no wonder why I got rid of it.
Old 09-24-2012, 03:10 PM   #25
ClapperHighs
Yeah, it looks like the only difference between this and the bsh one is the maf location. This intake has it a bit closer to the bend In the pipe. And thats it. But yeah I've heard all these complaints about hard knocking and vibration and weird howl noises... I have had none of these problems, except that the rubber sealing did pop off like grambles mentioned, so I had to super glue it back on. Problem solved. So I guess bsh had an issue with build quality consistency. I guess I got lucky.
Old 09-24-2012, 04:23 PM   #26
MAD_GTI
MAD_GTI's Avatar
I had a rubber seal pop off as well, anyone know where I can get more seal like this?
Old 09-24-2012, 04:26 PM   #27
MAD_GTI
MAD_GTI's Avatar
Likewise, I've put aboout 150 miles on it, no CEL, no weird stuff, etc.
Old 09-24-2012, 11:08 PM   #28
ClapperHighs
I considered just emailing bsh to send me new ones, but then I realized the same thing would just happen again. It seems like the heat just melts the factory adhesive. So I spliced them and superglued them back on, and now its good and strong.
cts turbo, intake, mkvi
