Getting misfires and ruff idle... CEL & EPC lights on
Jamester
Hoping to get suggestions on my problem. For the past month when I first start the car up in the morning it will be misfiring with the CEL blinking. I'll drive it like this for about 2 miles shut the car off for about 20 minutes. After I let it sit I restart the car and all seems normal (CEL still on) like there's nothing wrong. The CEL test reads Multiple misfires in a given period of time. I've checked the fuel, disconnected battary for 2 hours to reset computer, new plugs and coils with no discoloration or residue, unplugged maf no change and looks clean. Checked fuses all good. No idea what to do next I like to fix my own vehicles and trying to avoid paying a shop. Only thing I can think of is a bad tune (stage 2) but it's been fine for the 6 months I've had it. Any suggestions?
sterkrazzy
My guess is plugs or coils, and you should stop driving it with a blinking CEL.
Jamester
Plugs and coils are brand new and still look new when I inspected them. And this only happends when I first start it up in the morning then it's fine the rest of the day.
sterkrazzy
Blinking CEL + EPC + misfires is almost always a coil or a spark plug. I can't think of what else it might be, but maybe someone more knowledgeable has a better idea. You might get some better answers if you get it scanned too.
corydd
Could be an injector... but most likely a spark plug or coil pack. Have you checked error codes to see which cylinders are misfiring? I would try getting some R8 coilpacks. They usually fix the problem.
Jamester
Just got the CEL scan.
-P0100 mass or volume air flow A circuit
-P0304 Cylinder 4 misfire detected
Jamester
I have the R8 coils packs on already and autolite platinum plugs about 3 months old.
sterkrazzy
It sounds like p0100 could be a faulty MAF? I tried finding some results on google, but didn't really come up with anything other than the MAF. You could try a MAF cleaner. I'm not sure if that'll help or not though, I couldn't find a lot of info on that code.
I've experienced a bad MAF in my last car, but it's like you described. It would misfire and it had a really rough idle, I think I probably even stalled it a few times. When I unplugged it the car actually ran better, and I drove like that for a day or 2 until I got a new one, but you said you tried that and it didn't change anything...
Idk man, that's as much as I can help lol
The Fixer
Sounds like maybe the wire harness for the MAF? Autolite plugs wouldn't be my first pick, but have you ever had the intake manifold replaced or a carbon clean?
Jamester
Nope no carbon clean and stock intake manifold. I'm at about 63000 miles and I know I'm going to need to do that soon.
Jamester
Could I be throwing a maf code cause I disconnected it when I was testing?
pamatt
I had the same problem. It was my intake manifold.
Jamester
