Just want to let you guys know that if any of you interested to upgrade your stock brakes into Cayenne Brembo 6 pots front and 4 pots rear calipers w/ performance rotors, hit me up, I can help. I put together the kit myself and had it installed on my MKV and they not all that hard. They aren't cheap by any means but compare to buy this exact kit from vendors, it's a fraction of the cost and may be we even get better quality parts. Compare to the R32 brake system, this is by far superior and surely the most bang for the bucks, on or off track.
Front brake will mount w/o adapters, includes:
1. 6 pots Porsche Cayenne progressive calipers
2. 350mm brembo rotors. Optional light weight, two pieces rotors (17.2 lbs vs 25.7 lbs)
3. Stainless steel braided brake lines
Cost to put together a complete kit yourself. Less than $1000
Dual rear calipers brakes set-up fit w/ adapters. Parking brakes function by an extra pair parking calipers.
1. 4 pots Porsche Cayenne progressive calipers
2. Brembo parking/e-brake calipers.
3. 330mm brembo rotors. Optional 335mm light weight, two pieces rotors (12.5 lbs vs 19.55 lbs)
4. Stainless steel braided brake lines.
5. CAD/CAM designed, corrosive resistance T6160 aluminum brackets, CNC cut w/ high tolerance.
Cost to put this together yourself: $1200 depending on the cost and availability of
used brembo parking/e-brake calipers. New brembo e-brake/parking calipers starting at $990/pair. Basic (non-brembo) parking caliper $300/pair
Dual rear calipers set up is commonly found on high end, high performance, track racing and rally cars. It eliminates the use of shoes/drum e-brake which has large unsprung weight due to composite drum on the rotor, therefor save gas/performance. If you're unfamiliar w/ dual calipers rear set up, check out Dodge Vipers, Jaguar S type R. Those system are less common due to the high cost of manufacturing, but it's the best system that money can buy.
Cayenne calipers are progressives, meaning they have two rows of calipers on each side going from smaller pistons to bigger. This will prevent the jerking on/off locking mode of a regular calipers. Cayenne calipers feel like a forgiving everyday street drivebility , but give you all the control on the track when you need it.
This is what it looks like on my car.
