Old 03-12-2018, 02:02 PM   #1
Zach0918
Touring Car Newbie
Drives: 2014 Golf, 2.5L, Candy White
What DG springs will fit my 2.5L?
I have a 4 door automatic 2.5L GOLF. Was considering swapping out my stock springs out for DG springs once they need to be replaced. Iíve seen there are different versions of the DGs, would I use the 4 door DSG type? Is there a certain part number I should be looking for?
Zach0918 is offline   Reply With Quote
Old 03-12-2018, 02:12 PM   #2
MLue1
FIA GT Champion
They should all fit, the weight distribution difference between 2 and 4 door models shouldn't be an issue.
Old 03-12-2018, 04:35 PM   #3
drux
Drives: 2011 Golf 2.5L
I was wondering the same thing, except I have a 2-door. For example this page says these springs are only available for the 4-door model: https://www.ecstuning.com/b-genuine-...gs/5k4071677a/
Would they still work for a 2-door?
drux is offline   Reply With Quote
Old 03-13-2018, 01:48 AM   #4
Wascally Wabbit
Rally Car Newbie
Yep. Like he said 2 or 4 door shouldn't be that big a deal. Manual 2 door vs DSG 4 door maybe but still probably not. I was looking into going this route as well but talked to some people who had done it and they said the ride was a little to harsh for a daily driver (that was purely opinion though). I ended up swapping out to gti suspension instead which for me is perfect. Suspension is a system and springs are really only part of the equation. Sway bars (front and rear) and tires are equally important to how the car handles. Don't cheap out on the tires.
Old 03-13-2018, 11:26 PM   #5
Zach0918
Touring Car Newbie
Thanks for the advice. I just picked up and installed a set of Continental DSWs on 17s. They came highly recommended on this forum. With the GTI suspension did you notice any drop? I am not looking for anything extreme, just something that will hug the 17s a bit closed then the stock golf suspension.
Old 03-14-2018, 12:18 AM   #6
Wascally Wabbit
Rally Car Newbie
It definitly sits lower but there is still wheel gap. I am running Conti DW's on 17's as well.
Old 03-14-2018, 06:44 PM   #7
MLue1
FIA GT Champion
IMHO The MK5 and MK6 share the same suspension, unless your in it for the looks and stance, the GTI ride height/camber curve is about as low as you should go for performance driving. If you set your droop lower you start at a point where too much negitive camber gets introduced earlier than is required, hence the use of larger and larger sway bars to correct the geometry.
Old 03-21-2018, 09:55 PM   #8
Zach0918
Touring Car Newbie
Anyone know if these would fit the 2.5L? Seller is unsure.
https://worcester.craigslist.org/pts/6535082169.html
Old 03-21-2018, 10:59 PM   #9
Rickybobbi
Rally Car Champion
Drives: 2011 golf 2.5 MT / 2013 MB GLK-250
try contacting the company that makes them and ask.
2011 GOLF 2.5// LED TAILS // 18" BLACK RIMS // 2 12" KICKER SUBS // REAR EMBLEM BLACKED OUT // FRONT EMBLEM BLACKED OUT // DE-BADGE REAR // LED INTERIOR // HID HEADLIGHTS // 8" ANDROID HEAD UNIT // 35% TINT ALL AROUND // FK STREETLINES // OEM GTI EXHAUST //
Rickybobbi is offline   Reply With Quote
Old 03-22-2018, 12:39 AM   #10
MLue1
FIA GT Champion
Thumbs up
Zack, they will fit the entire Mk6 family. The 2.5 block is a tad bit heavier than the 2.0 TSI but that is balanced by the weight of the turbo and accessories, so should be no issues, they were prolly made in Europe so the 2.5 was not listed that's a common occurance.
These springs are linear like the original GTI ones, the original GTI setup specs should be used, not the 2.5.
Old 03-22-2018, 11:10 PM   #11
Zach0918
Touring Car Newbie
Thanks for the info as always, I wish I knew a quarter of what you do. Can you clarify what you mean by setup specs? Thanks (dory if this is a noob question)
Old 03-23-2018, 01:21 AM   #12
MLue1
FIA GT Champion
By design the GTI settings are more aggressive than that of the Golf. Once you put the GTI Springs on, it is best to use the more aggressive alignment specs for the GTI to get the base bang for your buck.
Just tell the alignment shop to use the specs for the GTI of the same year.
You can add Hotchkis 27mm swaybar(s) or another manufacturer at a later date to complete the transformation. I only mentioned Hotchkis as that's what I use. If you already have sway bars then its a mute point.
Old 03-23-2018, 05:59 AM   #13
Zach0918
Touring Car Newbie
Oh okay I see what you are saying now, thanks agsin
