My 2010, stock, no lag or latency.
So if you go press your gas pedal with your hand, from higher on the pedal, very gently, it responds with the first bit of movement? My '12 had this dead space when stock and tuned. The first ~10% of pedal travel, no matter how long you hold it down, will not raise the engine speed at all.
I'll have to be the first to admit. I have never pressed my gas pedal with my hand.
Okay, spoke with Commonwealth VW. They said that revision N is newer than D. If they were to replace my pedal today, it would be the exact same part number I have now.
As per excelvant the latest number we want is 1K1-721-503-AN
Allset can you confirm?
Paul...nice find as usual!!!!!
If you get the updated part and it works, I will buy it immediately and install it. Although, I don't really want to mess with the gas pedal. If something goes wrong taking it off or re-installing it, I will start throwing tools around my garage because I obviously won't be able to drive the car. So, maybe I will do it with you one Wednesday.
My car is a 2011...built on 2/11/2011.
This is so **cking annoying and also dangerous! A few times this could have cost me dearly. It needs to be fixed!
After going K04...I just can't believe that this still happens.
I can't understand why some people have the problem and some don't but, we have had that happen in the past haven't we?
Just to be clear: Revision N will not fix the dead space in the pedal.
I found a revision B that claims to be for the 2012 TTRS, but it wasn't available for purchase from the site that listed it that way. I searched for the same part # on Keffer, it came up for $127.50
Also, found K on Keffer as well.
Part Number 1K1721503AK
Part Name Throttle position sensor, gti, manual trans
MSRP $180.00
Core $0.00
Online Price $135.00
Also here, for $180
I'm not sure if this has been stated, but the pedal differs between manual and automatic transmission.
Alright now check this out.. many different revisions available
MSRP $180.00
Core $0.00
Also here, for $180
Currently sent an email to my service friend, waiting on a reply as he's checking my VIN to see which part I have if they can upgrade me under warranty.
Let me know!
CONFIRMED THROUGH VW = 1K1721503AD is the latest part number for 2010-2012 Golf and GTI's.
Turns out I have the latest 1K1721503AD Accelerator Pedal Position Sensor 2 (G185). 2011 GTI, manual transmission, 7/28/2010 build date.
