How can i increase boost?
Modshack1
Approximate boost PSI
Stock - 8 PSI
Stage1 - 15 PSI
K04 Turbo - 20 PSI
I'm at 12 PSI (stock) with my Boost Machine, but that's about as far as you can push it un-tuned..
XGC75
I get 12.5 stock (via VCDS, peak) and I hear stage 1 is 18. What gives with all these different read outs?
butchered by autocorrect
Modshack1
littleazn248
So is this a replacement for the DV so you can dial how much boost to hold before vent?
Modshack1
Uh...No. The DV doesn't have anything to do with making boost. This adjusts the air signal to the Wastgate actuator . Read more at the link.
littleazn248
I'm always thinking the DV is there to hold boost. After some googling I see the true purpose.
chrisisnapping
have you tried this on a tuned car yet?
then again I think there isn't too much room left in the IHI turbo after stage 1/2 anyways.
Keizerjohn
Stage 1 risk
Smiley, besides the dreaded "modbug", be aware that the 30% increase in torque from an APR Stage-1 tune will probably cause clutch-slip if you drive a 6M. I have a 2012 only 5 months old and got the tune 2 weeks ago. Unfortunately the stock clutch just can't seem to handle the extra torque in gears 4-6.
