Vw to porsche boxter brake upgrade parts list & future DIY
hockeystar17mnj
Found calipers on ebay for $170 each side.
Apikol sells brackets for $240 which is absurd
yes it's alot.unfortunately no one else makes them to keep the bracket price under control. but you can still find used brackets online from ppl parting out their kit.
if your getting these off of Ebay used. get all the maintenance items in my list. also get new dust seals. you don't want them leaking on the car.
hockeystar17mnj
wheel spacers, & porsche vibration dampers arrived today.
Hit a little snag though. While checking the Perf Diesel brackets I found that the bolts supplied from apikol dont match up. So i ponied up the dough and bought the apikol brackets. If anyone wants the Perf Diesel brackets for a side project or feel like figuring out the bolts required let me know
hockeystar17mnj
hawk hps pads, ecs rear lines, apikol brackets will be here tomorrow.
That should wrap up the ordering process. Install will happen next week as long as i have a clear day
hockeystar17mnj
Painted calipers tonight
hockeystar17mnj
Looks good:thumbsup:
Thanks
Waiting for them to cure and the motive brake bleeder to arrive so I can do this install this weekend.
the bruce
piston size/area
1. stock front caliper:
Golf/GTI - Ate FN3 54 mm caliper: 2290 mm²
S3/R32/R - FNRG 57 mm: 2552 mm²
2. aftermarket - proper match:
Boxster: 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
Brembo GT caliper A: 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
Stoptech ST-40: 38 mm + 34 mm > 908 mm² + 1134 mm² = 2043 mm²
3. aftermarket - poor match:
Forge: 707 mm² + 1046 mm² + 1164 mm² = 2917 mm²
Q7/Touareg/Cayenne (three variants):
34/36/38 mm : 907.920 + 1017.876 + 1134.115 = ~ 3060 mm²
32/36/38 mm : 804.248 + 1017.876 + 1134.115 = ~ 2956 mm²
30/34/38 mm : 706.858 + 907.920 + 1134.115 = ~ 2749 mm²
4. master cylinder diameter:
- 22,22 mm > 388 mm² (Mk.V GTI)
- 23,81 mm > 445 mm² (Mk.V R32, Mk.VI GTI, Golf R)
- 25,40 mm > 507 mm² (RS3 + TT-RS)
ps
If you know the piston diameter: Pi * radius² = area
the bruce
Steve, if you or anyone else has info on any caliper piston sizes - please let me know.
Modshack1
Will do...Nice work on the calc's BTW....The Brembo's feel perfectly balanced regarding Bias, and this pretty much verifies it..
the bruce
AP Racing kit added:
piston size/area
AP Racing 6-pot CP7068-00 (355x32 ) > 2350 mm²
ps
hockeystar17mnj
piston size/area
ps
AWESOME!
Great info. Keep this updated and once a "semi complete" list is made Ill put it in my OP to make it easier to figure out the total area for each kit.
Install was delayed due to my friend with a garage to use had the flu so I wasnt able to go there and install this. Hoping for this weekend
the bruce
Found some more - Boxster S and 993/996 Turbo:
piston size/area
Boxster S: 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
993 Turbo: 36 + 44 mm > 1018 mm² + + 1520 mm² = 2538 mm² (on the edge)
Brembo GT 'A-caliper': 40 mm + 36 mm > 1257 mm² + 1018 mm² = 2275 mm²
996 Turbo: 40 + 44 mm > 1257 mm² + 1520 mm² = 2777 mm²
- 22,22 mm > 388 mm² (some Mk.V GTI, Mk.V + Mk.VI Golf)
- 23,81 mm > 445 mm² (Mk.V R32, Mk.V GTI, Mk.VI GTI, Golf R)
hockeystar17mnj
teaser for tonight. will be updating tomorrow. overall I love the brakes. squealing a little at low speeds like others have said
