I was browsing Crutchfield for a new head unit for my 2011 Golf 2.5 base model, and came across the following "Installation Details"
My other option is to get an OEM touch-screen radio. If I were to do that, would I need to get the MDI interface box, or just the cable to connect to the radio? That darn box and cable would cost me ~$400 to add to my stock bottom of the barrel radio.
I was wondering if this was necessary? My car doesn't have an upgraded sound system, or OnStar. For $129.99 I could buy a new (crappy, low-end) head unit. That seems like an awful lot of money to spend on an extra wiring harness. What does it do, and is it really needed? Or only on the models with the "fancy" radios?Your vehicle is factory-equipped with an upgraded sound system. We strongly recommend that you purchase an adapter that maintains your factory door chimes (required for audible safety warnings), provides a switched 12-volt power source for your new radio, and allows you to continue using the OnStar feature. You should not replace your factory radio without this adapter. PAC C2R-VW2 $129.99
