Old 06-27-2018, 10:58 AM   #71
raphaelpmc
Drives: Fusca 2012 (Beetle)
Great topic, I did my self this replacement, is not so hard but a Lon time work, be carefully when necessary, because this work accepts no mistakes or will leak again. Take care with the bolts on, take care with the belts return, take care with the water/oil coolant junction, and replace when possible all the o rings !
raphaelpmc is offline   Reply With Quote
Old 07-16-2018, 11:38 AM   #72
GuiltySpark
GuiltySpark's Avatar
Drives: 2012 GTI
So my 2012 GTI had the recall done at a dealer in 2016. Last week it began overheating and after taking it back to the dealer (they were only able to diagnose it for a little bit, I took it on saturday and they close at 3PM) they said its likely a stuck closed/failed thermostat as the inlet is hot and the outlet is cold.
Oddly, i thought thermostats were always supposed to fail open.. anyway...
So they saw that its already the latest water pump so that its not covered under the recall/warranty, even if it needs to be replaced (looks like the thermostat is built in?). Its NOT leaking.
Does this sound correct or should I be fighting this?
GuiltySpark is offline   Reply With Quote
Old 07-16-2018, 01:48 PM   #73
GuiltySpark
Drives: 2012 GTI
Well they submitted a request to VW Good Will to see if they'll cover the already replaced water pump as they don't replace just the thermostat. Not going to get the car back today :-/
I sure hope its covered.
Old 07-27-2018, 09:42 PM   #74
ChrisB
FIA GT Champion
ChrisB's Avatar
Drives: 2013 MKVI Driver's Ed German Fit
I'm about to do this water pump thing myself. I am not under the service campaign and the stealership quoted me "about $900" to do it over the phone. Good job since it went at 60,200 miles...
EDIT: Well, I finally did this and I liked it so much, I did it twice.
Lessons learned: get at least ONE injector seal kit AND replace the union between the water pump and the oil cooler. One of my injectors that pulled with the manifold broke a claw. I didn't want to find out how well the car would run long-term with that piece compromised, although it did run fine, prior to discovering another leak...
My main problem came from the union. Water poured out like never before at the reused union. My OG unit was sketch looking but I figured it would work, and I was WRONG. I put a deposit down for a Powerbuilt Loaner Pressure Tester Adapter at Autozone just to make sure no other leaks were present prior to replacing the union. When I was done, it also doubled to pressure fill the cooling system.
The good news is that water pump whine is now gone, along with the leaks....
Unitronic: Stage 2 ECU, Stage 2 DSG, TBE
Other: Enkei PF01 17X8 ET50s with Pilot Super Sports; R8 coils; NGK BKR7EIX plugs
Audio: Kenwood DNX891HD; Audison BitOne; MMATS HIFI-6150D; Genesis Profile 16 components, run active of course; 10" Alpine Type R
ChrisB is offline   Reply With Quote
Old 10-13-2018, 03:59 PM   #75
Wagenmightbreak
Drives: 2011 MK6 GTI Autobahn
Reviving this thread but how the hell did you get the new belt on without loosening the tensioner? Ive been at it for hours trying to get that new belt on and it WILL NOT fit between that crease on the bottom crank.
Sent from my HTC 10 evo using Tapatalk
Wagenmightbreak is offline   Reply With Quote
Old 11-03-2018, 09:15 PM   #76
Steve Lai
Drives: 2012 Golf GTI Mk6 4 Dr DSG
Its a 12 mm nut bolt in the bottom. It should be loosen in opposite direction.
Steve Lai is offline   Reply With Quote
Old 11-07-2018, 06:16 PM   #77
TheRickestRick
Newbie
Drives: 2012 GTI
Originally Posted by GTIProject View Post
I've done this job 20x times on various customer cars, my own car and many, MANY more A4's with the EA888 motor. Few things to clarify;
-You DO NOT need to remove the IM to do this, remove the TB, TB hose and front elbow pipe. I'd suggest tucking some of the wiring up and out of the way.
-The 12mm bolt is a REVERSE thread and really only needs to be loosened 3-4 turns to relieve tension on the belt. I usually cut the old belt off and and break the the 12mm loose with the old pump out. USE a 6-POINT socket. Use a 12 point and you will destroy your knuckles, or strip the head of the bolt.
-The connector piece should be replaced with the updated (black) part.
-Replace the 2 shorter bolts that join the pump near the ECT sensor - they usually get corroded and are hard to re-thread.
-Replace the o-ring to the coolant pipe that goes into the front of the engine. VW also has an updated part the superceeds and replaces the pipe with the thicker version to prevent stress-induced cracks. It's $30-40 and worth the insurance.
A lot of people shit on flat-rate techs and dealer techs for no reason. There are a lot of hacks out there, but there are also plenty of shade-tree mechanics that don't do much better. Not trusting someone to do their job because of how they get paid does not seem fair if you have not had work done before. I'm a flat-rate tech and while there are plenty of short cuts taken to save time - doing the job incorrectly wastes more time than doing it right in my experience. Time is made by knowing what to do, how to do it and where to do it correctly.
Don't know if anyone is still checking this thread. What kind of socket can you get on that 12mm bolt? I know I can't get a 3/8" 12mm socket in there, not enough room. I tried a box wrench, but it only grabs the very end of the bolt and slips off. Maybe an offset box wrench would get a better hold. Is there a special low profile 1/4" 12mm socket I need to get? Thanks.
TheRickestRick is offline   Reply With Quote
