Old 03-31-2017, 05:34 PM   #505
BringerOdeath
BringerOdeath's Avatar
Drives: 2011 GTI Candy White
Originally Posted by jackhossross View Post
Okay - sorry, I want to make sure I am on the same page with you.
I drive a 2013 Golf R, with 18z Front Calipers
I need to upgrade my Brake Master Cylinder with a Mk2 Audi TT (S or RS models only).
Or the kitted version by HSTuning.
Thank you so much for your help folks.
What is the part no. of said BMC? I will modify the reservoir hole to fit the bolt.
Sent from my iPhone using Tapatalk Pro
8j1611021e
that is the part number for just the master cylinder
K04 G.I.A.C. Tuned, Godspeed FMIC V2.0, R8 red Coilpacks, Volant Intake, Fastbits DV+,42 Draft designs DP-high flow cat, Fluidampr, 034 motorsports street engine/tranny mounts, Vibratech Subframe insert, 034 motosports aspherical dogbone, 034 stainless subframe collar kit, IE Africa plate, AWE S3 style Charge /discharge pipes, Koni Coilovers, TSW Donington wheels, Golf R side skirts, TTRS BBK, Dual caliper Cayenne rear BBK
Old 03-31-2017, 05:53 PM   #506
jackhossross
jackhossross's Avatar
Drives: VW Golf R '13 2D Rising Blue
Originally Posted by BringerOdeath View Post
8j1611021e
So, this is listed as TT-S, no mention of RS.
This would be an upgrade to the Golf R BMC, correct?
LINK ---> Audi Parts, BMC
jackhossross is offline   Reply With Quote
Old 03-31-2017, 06:01 PM   #507
BringerOdeath
The golf R mk6 uses this part I believe:
1K1614019K
Which is the smaller cylinder marked with a "22"
Old 03-31-2017, 06:05 PM   #508
BringerOdeath
https://www.parts.com/index.cfm?fuse...ASTER-CYLINDER
Part also listed for TT-RS 2.5liter 2012-2014
Old 03-31-2017, 06:05 PM   #509
jackhossross
1K1614019K
Haha I think we are spinning our wheels here ...
I am looking to upgrade FROM the Golf R BMC to a Audi TTS BMC that supports the size of the 18z.
SO, I am moving from part #1K1614019K (Golf R) to #8J1611021E (Audi TTS)
Haha I think this is getting more confusing than it needs to be. Am I in the incorrect thread? I am guessing I am missing something ..
Old 03-31-2017, 06:06 PM   #510
jackhossross
ah! thank you .. so we can disregard my prior comment.
Thank you so much .. truly appreciate it.
Old 03-31-2017, 06:16 PM   #511
Cadubya
“DUBYA” VP COUCH MOD
Cadubya's Avatar
TT-RS/Golf R master cylinder
1K1614019K
The 25.4mm master cylinder 8J1611021E was found on MK2 USDM A3 3.2's and TT 3.2's, TTS's and the TTRS.
http://www.jimellisaudiparts.com/pro...J1611021E.html
CLICK HERE FOR MY BUILD
Old 03-31-2017, 06:25 PM   #512
BringerOdeath
YW!! No problem man, I spent a lot of time looking for the correct master cylinder. I got lucky and found one that was listed under the C version instead of E and it turned out to be the E version we need.
Old 03-31-2017, 06:42 PM   #513
LAGP
Drives: Audi A3
Just be aware that sometimes the compatibility list is not 100% accurate, make sure you get the 25 mm bore MC, here is a complete description on the part you mentioned:
Sent from my Moto G (4) using Tapatalk
LAGP is offline   Reply With Quote
Old 03-31-2017, 08:45 PM   #514
jackhossross
Fantastic - I will make sure to get the 25,4 size.
Old 04-18-2017, 09:44 PM   #515
GTI2Slow
GTI2Slow's Avatar
Drives: Slow
Can anyone detail what they did to modify the GTI fluid tank to fit the 25.4mm master cylinder?
Do you just need to drill out the holes in the tabs to accept the larger bolt/stud?
Edit: For those that installed a new MC, did you bench bleed it before installing it? I have a Motive power bleeder that I plan to use.
Mk5 slumming it up in your Mk6 forums.
GTI2Slow is offline   Reply With Quote
Old 04-19-2017, 03:50 PM   #516
BringerOdeath
Mine came with the res, but from what I read, you only have to drill the hole bigger to fit the larger bolt.
Old 04-19-2017, 06:09 PM   #517
GTI2Slow
GTI2Slow's Avatar
Drives: Slow
Thanks!
How did you bleed it, I can bench bleed mine but I think it will just be a mess and a hassle. Not sure if the power bleeder can do it alone.
Old 04-19-2017, 06:46 PM   #518
BringerOdeath
Thanks!
I bled mine with the brembo nipples on the calipers..... :P
