Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Technical Topics > Exterior / Interior Care (washing, detailing, exterior repairs)
Old 04-16-2019, 06:01 PM   #1
reiniday
Newbie
Drives: VW GTI
Question 2012 GTI Sunroof Problems
My sunroof just decided to stop opening. The motor works, and you can hear it prop up to open but then it just goes back down and wont slide all the way open. I have tried to open it partially as well as completely and it just doesn't want to go.
Has anyone else had this issue or know how to fix it?
reiniday is offline   Reply With Quote
Old 04-17-2019, 12:07 AM   #2
jer891
Newbie
Drives:
Probably a broken groove the same thing happened to my mk5 but I am. It wasting money to buy a new one u can get one from the junk yard tho
jer891 is offline   Reply With Quote
Old 04-17-2019, 12:19 PM   #3
Squashdaddy
FIA GT Champion
Squashdaddy's Avatar
Drives: 6MT 2011 GTI
I had the same issue with my 2011 GTI. As I recall, instead of turning the dial to open it, you actually tilt the dial to override. I did that and it started working again. No further problems for the past couple of years.
APR Stage 2 ECU - APR Carbonio Stage 1+2 - 42 Draft Designs Catted/Resonated Downpipe - Neuspeed Charge Pipe and Turbo Outlet Pipe - GFB DV+ - Fluidampr Crank Pully - HS Tuning RSR clutch -H&R 24mm rear swaybar - Unibrace UB - HPA Red Puck -Neuspeed Rse12 Hyperblack
Squashdaddy is offline   Reply With Quote
Tags
diy, repair, roof, sunroof
