Old 01-19-2017, 08:20 AM   #5881
vwgti2.0t
Drives: 2011 CW GTI
Mine is an internal gate, and it's full open at like 8psi (aka wastegate pressure). But 70% duty cycle is 20-22psi and 80% is 28-30psi. That's just a set duty cycle across the board. I'm actually going to be installing a scramble button next month, so when I'm at the track I can launch in first and second on the 70% duty cycle setting and then when I hit third hit the button to go to 80+% duty for the rest of the run.
Old 01-19-2017, 01:02 PM   #5882
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Me too, internal gate with 1.5bar WG spring. Drove the car today and partial throttle cruising was terrible. Kept the Greddy EBC on the controlled setting but dropped the start to 1psi so the solenoid duty cycle is 100% from vacuum to 1psi. From there I have it at 40% duty cycle from 1psi to whatever I'll reach and maintain witha 5% gain.
Can someone expand on scramble, what it does and when it would be used?
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 01-19-2017, 01:20 PM   #5883
vwgti2.0t
Drives: 2011 CW GTI
On my Tru-boost it's a function that when a certain wire is grounded it'll switch to a specified duty cycle for a specified amount of time. So in my case, I'm going to hook it to a push button. At the track, launch and get through first and second on 20psi to maximize traction, then hit the push button to switch to 30psi to finish the run out where more traction is available. That's my plan anyway.
Old 01-19-2017, 08:29 PM   #5884
A3Scott20
A3Scott20's Avatar
Drives: 2013 A3 DSG
Ryan, have you tried setting boost according to Greddy manual?
Currently my EBC is set :
A3Scott20 is offline   Reply With Quote
Old 01-20-2017, 07:33 AM   #5885
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Attachment 54727
Attachment 54728
Thanks Scott, I made changes last night and the normal driving conditions are MUCH better, I think it has to do with changing the START to 1psi. Next I'll work on SET as I approach my fuel limit before turning on the port injectors. GAIN last.
YouTube: HYDE16
Old 01-20-2017, 08:59 AM   #5886
kern417
Drives: '09 Jetta
mine holds closed until i think 7psi? and then 40% duty cycle was ~20 psi. 1 bar wg spring.
plan is to go down to a 10psi spring and use the 4 port solenoid with cortex to get better control with boost by gear. i'm pretty excited to get that going.
do a burnout.
Old 01-21-2017, 08:48 AM   #5887
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Huge help to *****2.0t for spot checking my Eurodyne base file and making the necessary changes to start increasing boost.
For other ED users, what do you have your idle set to? Mines running around 750rpm
YouTube: HYDE16
Old 01-22-2017, 04:25 PM   #5888
VEEDUBBER
Drives: 09gti gtx28, 15gti, 01 S4
So far so good with the LDKs. No more missing up top. I also had to stud the 2 lower outside manifold bolt holes since the threads came out the bolts. Maybe getting a leak there?
Thanks for the pointers on the fueling Nick! Andy Samland also smoothed out a ton of driveability issues too that I'm pretty sure the other "tuner" never changed from the base file. I didnt realise how terrible it was until now. Significant improvement over the APR software as well.
Sent from my SM-G930P using Tapatalk
VEEDUBBER is offline   Reply With Quote
Old 01-22-2017, 05:43 PM   #5889
mikejsmith1985
Andy tuned my car he's a good guy to work with if you want to know about the changes being made to each file iteration.
www.tunemaestro.com
Old 01-29-2017, 11:51 AM   #5890
wndwsdwngti860
Drives: gti
so where is everyone pulling pressure readings from the compressor side? my gtx has no tap and i had a tap on my ic pipe but i want to have the best possible spot while im redoing my setup. id rather not drill and tap the turbo so should i just go into my ic piping again?
wndwsdwngti860 is offline   Reply With Quote
Old 01-29-2017, 05:33 PM   #5891
jettaglx91
Drives: 450whp TSI GTI, 420whp R, stock CC
Anyone in here by chance have a Meastro file for a 115AL ecu? Should be from a 2010 Gti CBFA. Waiting for support but was hoping to get one asap
jettaglx91 is offline   Reply With Quote
Old 01-30-2017, 12:02 PM   #5892
kern417
Drives: '09 Jetta
i think i sent you a link already but this is what i used with my gtx 30. i just tapped the turbo outlet pipe. cheap and easy to install.
http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
do a burnout.
Old 01-30-2017, 05:30 PM   #5893
wndwsdwngti860
Drives: gti
yup that was me
Old 02-02-2017, 12:00 AM   #5894
wndwsdwngti860
Drives: gti
Top Mount update:
downpipe fabrication started tonight. first half is done (pics tomorrow).
Heat shielding on the way from PTP.
Need to work on o2 sensor extensions now.
addicted to torture, blow up ur volkswagen, breaking your trans 101, failwheeldrive anonymous, fireball lives!, james'partout
