Old 04-21-2018, 01:39 PM   #29
GIACUser
FIA GT Champion
GIACUser's Avatar
Drives: 2008 MKV EFR7163
Originally Posted by PeeLo801 View Post
Thank you.
Its important to use a proper kit. The drill bits in the kit spin left (unscrew), they come with guides for the bits so it centers your drill bit and then the special extractor the digs into the hole you drill and bites.
| 2008 GTI | Turbozentrum EFR7163 | LSD | UNI custom DSG tune | Aquamist W/M | Brembo brakes f/r | Eibach R1 Coilovers | Neuspeed RSe11 18x8 Michelin PS4 | Recaro Speedseats |
Old 04-22-2018, 11:09 AM   #30
PeeLo801
PeeLo801's Avatar
Drives: mk6 GLI DSG Black Pearl Metallic
Originally Posted by GIACUser View Post
You normally get them out with an easy out screw extractor after soaking it for a while with something like PB Blaster solvent. That way you can preserve the threads.
Still doing my research on this in order to evaluate options. This is the very top bolt that's hard to reach, so do you think it's possible to do take out this stud without taking out the turbo? The shop insists they have to take it out, but I suppose they want to go with what's easier and less time consuming for them.
GIAC K04 Tune // APR K04// Unitronic FMIC // Neuspeed p-flo intake // AWE Downpipe // TSW Nurburgring // DG Springs // Koni Yellows // Unibrace UB & RB // Hotchkis Front and Rear Sway Bars //
Continental Control Contact Sport
PeeLo801 is offline   Reply With Quote
Old 04-22-2018, 11:47 AM   #31
GIACUser
FIA GT Champion
GIACUser's Avatar
I will ask my mechanic friend and get back to you later today. This guy has a lot of time working on these motors.
Old 04-22-2018, 12:19 PM   #32
GIACUser
FIA GT Champion
GIACUser's Avatar
Well my advice was crap. I asked my friend who was a full time VAG mechanic. Here is what he said.....
"Chances are an easy out won't do it. At least in the car. The exhaust studs are a pain when they break. Best way is to yeah remove the turbo and work with it on the bench."
His response is consistent with what your mechanic is saying.
Old 04-22-2018, 12:46 PM   #33
Geryon86
Geryon86's Avatar
Drives: MK7 R
Is there any thread left? Post a picture.
MK7 Build Thread
16' LB R | DSG | APR Stage II HT |
11' SB GTI
|DSG|APR v3.1|CTS K04|
Geryon86 is offline   Reply With Quote
Old 04-22-2018, 01:30 PM   #34
PeeLo801
PeeLo801's Avatar
Thank you very much. This is the kind of information I need to make an informed decision on how to move forward.
Old 04-22-2018, 01:32 PM   #35
PeeLo801
PeeLo801's Avatar
I don't have the means to take a photo, but I can get clarification from the shop. From what they said, they would need to "tap" it out. They didn't say anything about the thread being stripped.
Old 04-23-2018, 02:42 PM   #36
Geryon86
Geryon86's Avatar
Drives: MK7 R
I'm confused. Is the down pipe stuck on due to the one nut/stud? If so, you wont be able to pull the turbo. You need to apply a bunch of kroil and let it sit, and apply again and man handle it. Is the downpipe off and the stud stuck? If the stud isn't stripped then why do you need to take it out? If you're trying to replace the studs just because then throw on 2 nuts and back out the first nut that went on. Again, use a bunch of kroil or alike.
MK7 Build Thread
11' SB GTI
Old 04-23-2018, 02:51 PM   #37
PeeLo801
PeeLo801's Avatar
The downpipe is currently only screwed on by the other three bolts at the moment; the fourth one is the top hard to reach one that they could not screw back on because it got stuck as they were trying to take off my stock one to install my current one. So I just left it as is in order to get my car back. But as of right now, the top one has the stud stuck in the turbo so it is not screwed on at all. I hope this makes sense.
Old 04-23-2018, 07:03 PM   #38
BudgetPhoenix
FIA GT Newbie
Drives: 09 GLI
Is anyone else still a bit confused as to what this stud situation is lol?
There are no bolts from the factory. There's 4 threaded studs screwed into the turbo exhaust housing and 4 nuts that screw onto those to hold the downpipe on. So it sounds like they couldn't get the 4th nut to thread on the stud again which means it sounds like it's intact still? If so couldn't you just remove the downpipe again and that would give you enough room to just use a stud puller to remove the stud and use a new stud and new nut? You can easily reach all 4 studs with the downpipe off to use a stud puller on a 3/8 wrench.
Old 04-23-2018, 07:14 PM   #39
PeeLo801
PeeLo801's Avatar
Haha you actually get it for the most part, so you aren't as confused as you think. I don't know if I'm using the wrong terminology, so my bad for making it confusing. I'm just relaying it the way I understand it as I'm not much of a gear head.
The stud (which I've been referring to as bolt incorrectly?) that gets screwed into the turbo is stuck, and from my understanding, half of it broke off. So it is no longer intact. Thus, they cannot screw the nut back on to hold the downpipe. According to the shop, they need to take out the turbo in order to tap out that stud and replace it.
I hope that clarifies it.
Old 04-26-2018, 04:24 PM   #40
PeeLo801
PeeLo801's Avatar
Alright, just a quick update: I got further clarification from the shop that the thread is in fact stripped, so that's why they said they would need to drill and tap it out in order to rethread it. I feel like an idiot for misunderstanding it the way I did. In any case, they're confident it's an easy fix, but they will be taking out the turbo in order to do this.
So, I'm still mulling over my options between just getting this fixed for a fraction of the cost of getting a k04, or spend an additional 2K to get k04. I don't see myself selling this car anytime soon as I love my car, and i've wanted a k04 since I bought it.
I'm really tempted to go with k04 since they'll already be taking out the turbo, but I'm just hesitant on spending more on supporting mods, specifically a new intercooler, which i've read is a must. I think i've gotten over any concerns about smog implications from what people are saying, other than the fact I have to get a modified CCTA DP.
So anyone running a stock intercooler on their k04?
Old 04-26-2018, 05:07 PM   #41
APRMK6GTi
Formula 5000 Champion
APRMK6GTi's Avatar
Drives: 2012 GTI
You can run stock intercooler on K04, but it gets hot in Sac, and you will heatsoak and negate the power bump. I'll say try to pick up a good condition used K04 instead of getting a brand new one. In any case, for smog, u can borrow my modified CCTA dp.
2012 CSG GTI 6SPD | APR Tuned | AWE K04 | APR Carbonio | IE FDS IC | APR DP | Magnaflow | Neuspeed TOP/ACP | GFB DV+ | DG S6 | Fluidampr| OEM MSB | Verdict SBB | HST RSR | ECS Bleeder Block | SuperPro LCA/ALK | 034 Mounts | AST/GC | OZ | ST40| Whiteline 24MM F&R | Tyrolsport | Unibrace XB/UB/RB | EuroSport LB | Euro OEM LED | OEM Aero | P3 | VERUS |
Nor Cal VW Drivers Club
Old 04-26-2018, 09:13 PM   #42
GIACUser
FIA GT Champion
GIACUser's Avatar
x2 and a stock intercooler is also a choke point so you won't get the air flow you need on the top end.
Also even with a larger intercooler it is hard to lower IAT in hot weather when you are looking to run the car hard. Adding water meth to that larger intercooler works incredibly well for those of us in very hot climates.
