Old 04-25-2018, 08:57 PM   #85
franco516
franco516's Avatar
Drives: gti
Originally Posted by Jerseynoob View Post
Waste of money.
Not necessary.
Have 80k on my HPA, never needed one.
Thats what I thought. Theres alot of unnecessary bullshit thats sold for these cars, just making sure tho.
IG - @francotirador91
franco516 is online now   Reply With Quote
Old 05-04-2018, 10:28 AM   #86
franco516
franco516's Avatar
Drives: gti
Hey guys. Just realized my kit didnt come with this clamp.
Can I reuse the stock one? Or were can i buy one?
Old 05-04-2018, 11:36 AM   #87
OhioMK6
OhioMK6's Avatar
Drives: 2012 CSG GTI - 2DR Manual
Contact HPA. I've heard that clamp leaked for a few people as well so it may be worth having it welded instead. The stock turbo has a different outlet pipe so there's no clamp to re-use.
2012 CSG Manual
Borg Warner K04 | Stratified Protune | SouthBend Stage 2 Daily Clutch | ECS Tuning Intake - SPM Downpipe - Corsa RSC Catback - GFB DV+ - Audi R8 Coils + NGK IX Plugs - Koni Coilovers - 3SDM 0.06 Wheels - Hankook Evo V12 - HAWK HPS 5.0 Pads - ECS Tuning SS Brake Lines - Ziza Golf R Tails - ECS Tuning Street Shield - Eonon GA5153f Android Headunit
OhioMK6 is offline   Reply With Quote
Old 05-04-2018, 12:21 PM   #88
franco516
franco516's Avatar
Drives: gti
yeah i saw previous posts in this thread that ppl's were leaking. Maybe ill have the shop weld it. thanks for the info.
Old 05-04-2018, 01:51 PM   #89
OhioMK6
OhioMK6's Avatar
No problem. Try reaching out to the people who posted that for more details on the turbo outlet.
2012 CSG Manual
Old 05-08-2018, 10:27 AM   #90
franco516
franco516's Avatar
Drives: gti
gonna run a turbosmart wastegate with 7psi spring. should that be good enough?
Old 05-08-2018, 05:20 PM   #91
redubbed
Should be, yes
redubbed is offline   Reply With Quote
Old 05-08-2018, 05:32 PM   #92
franco516
franco516's Avatar
Drives: gti
Originally Posted by redubbed View Post
Should be, yes
actually I spoke with stratified today and they recommended an 11psi spring, since im probably gonna get their protune im gonna swap out the spring for good measure.
Old 06-07-2018, 12:08 PM   #93
franco516
franco516's Avatar
Drives: gti
anyone get a whiney sound coming from this turbo? just trying to figure out if its the turbo.
https://www.youtube.com/watch?v=wWZV-g9o2is
Old 08-14-2018, 10:54 AM   #94
KFahey
KFahey's Avatar
Drives: 2011 MK6 GTI-MT
HPA K04 Leak
Franco, sound like a boost leak. I had that leak as well where the intercooler hose connects to your pancake pipe. Check that connection.
FYI, I had a new ring, offset coupler, o ring and V-band installed on my turbo. The leak sounds the same and my car randomly struggles to build boost. Sometimes ill peak properly at 25-26 PSI and sometimes it will just slowly build up to 15 PSI when i floor it. Anyone else have this leak or similar symptoms?
APR K04 V3.1 | Unitronic CAI | CTS TBE | NewSouth Boost Gauge | R8 Coils | RSR Clutch Kit | OEM LED Tails | VWR Springs | KONI Yellow Front Struts | GFB DV+ | CTS Intercooler | 034 Street Mounts
KFahey is offline   Reply With Quote
Old 08-14-2018, 11:58 AM   #95
franco516
franco516's Avatar
Drives: gti
I actually had mine welded like the guy a few pages back in this thread. also, ive never experienced any boost issues. i should check for leaks tho anyways.
Old 08-14-2018, 12:11 PM   #96
KFahey
KFahey's Avatar
Im talking about a different leak on yours. Not at the turbo outlet assembly but where your intercooler hose connects to your pancake pipe.
Sent from my SM-G935V using Tapatalk
Old 08-14-2018, 12:19 PM   #97
franco516
franco516's Avatar
Drives: gti
oh true, i did spray soapy water on that connection but didnt see any bubbles. I have to take it to a shop tho im like used to the noise now.
Old 09-11-2018, 09:25 PM   #98
jeez
jeez's Avatar
Drives: 2011 GTI DSG SBM
Glad I found this thread. I get the P1335 code and it's been plaguing my car for months! I also have an HPA K04. Is this something that happens to most HPA K04 users? And all I need to do get under the car and see if it has that ring circled in red above?
I've done countless pressure tests....there's no leaks....but there is a whooshing and whining sound when under load depending on RPM. Limp mode between 2k-3k RPM. Also changed intake, PCV, DV. I'd be super pissed if this is HPA's fault as they already gave me a turbo with a crappy wastegate that I replaced with a Forge one.
2011 Mk6 GTI DSG SBM Autobahn | HPA K04 | Stratified K04 Protune (Member #1) | APR S1/S2 Carbonio Intake| APR K04 DSG Tune | Forge K04 WGA | Bosch 3 BAR MAP | AWE S3 IC | Neuspeed Throttle Pipe | AWE Turbo Outlet Pipe | Fluidampr Harmonic Balancer | 18" OZ Leggera HLTs | VW DriverGear DSG Springs | GFB DV+ | Continental DWS 06s
jeez is offline   Reply With Quote
