Old 06-13-2018, 06:57 AM   #1
D2JML
Drives: MK6 Gti DSG Candy White
DSG OIL change? when and how- URGENT!!
I have recently bought a golf gti 2009 DSG
I have recently done a full service on the car, oil change, oil filter, spark plugs, air filter, pollen filter, fuel filter, all coolants
I heard the DSG gear box its self needs to be serviced too
how is that done?
can someone please explain in basic terms what needs to be done
thank you
D2JML is offline   Reply With Quote
Old 06-13-2018, 07:47 AM   #2
flakomk6
Rally Car Newbie
flakomk6's Avatar
Drives: 2013 mk6
https://youtu.be/nhE19GCXlvA
flakomk6 is offline   Reply With Quote
Old 06-13-2018, 08:17 AM   #3
D2JML
thanks man,
do you have to do the vag.com side of things??
or can I just put it the same amount that I took out, to be sure its level and correct
Old 06-13-2018, 08:22 AM   #4
Ik1015
FIA World Rally Car Newbie
Drives: mk5 ug
how is that done?
thank you
Congratulation!
You bought ticking bomb...
Check timing tensioner, PCV valve, rear main seal, throttle body wire connector, etc......
Ik1015 is offline   Reply With Quote
Old 06-13-2018, 08:32 AM   #5
D2JML
Originally Posted by Ik1015 View Post
Congratulation!
that's all been checked- the previous owner did the dsg service at 38k miles but I thought I want to do it myself for good measure even though his given me the receipts etc
Why is it a ticking bomb?
Old 06-13-2018, 08:35 AM   #6
flakomk6
Rally Car Newbie
flakomk6's Avatar
Drives: 2013 mk6
That year is known for having those issues , unless the previous fixed it i will still suggest to have those looked at
Old 06-13-2018, 12:24 PM   #7
Ik1015
Drives: mk5 ug
Because I am driving ticking bomb, too...
ABS module, intake manifold, timing tensioner, rear main seal replaced. Rewired throttle body connector and also replaced cam position sensor (oil leaking).
I am lazy to replace upper timing cover gasket due to leaking oil.
Old 06-13-2018, 01:32 PM   #8
BudgetPhoenix
Drives: 09 GLI
09 TSI owner here too.
-Did a timing job myself due to stretched chain AFTER paying someone to do the tensioner. But I did everything myself the second time so learned a lot.
-Cam bridge screen was torn and sitting in oil passage in the head.
-ABS module failure which I DIY'd with a used MK6 module then the recall came out and I was SOL.
-Upper timing cover leaks
-2 PCV failures
-Steering rack throws random Torque sensor failing codes. Steering light occasionally comes on but has been driving fine for a few years.
Haven't had a intake mani failure since ive owned it yet. I'm sure it was replaced in the past. Done a few other things like MAP sensor replacement, carbon cleaning, DSG upkeep etc. DSG makes a clack on downshifts 3-2-1 sometimes but drives totally fine. This car has been a pain and costed a lot of $$$ but I enjoy it still. Thanfully I hadn't had RMS failure thankfully, and PCV has been replaced a few times at least.
Old 06-13-2018, 01:38 PM   #9
BudgetPhoenix
Drives: 09 GLI
Also TC look up the DSG top fill method and drain the overfill. Better than measure-fill because you don't know if it was underserviced before. Better to just put in the 5l and drain the excess. Usually comes out to about 4.6L needed for a service. You don't need the special under fill tool you can fill it from the top oil filter housing with a funnel and its not messy at all.
The TDI forums have a good write up IIRC. To do it properly you should use VCDS or something that can measure DSG oil temps because when you drain the excess overfill it should be at the correct temp. This is the same for even the factory filling method.
Old 06-13-2018, 06:53 PM   #10
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
I did mine this way and will be doing it again in 10k. Its simply as easy as doing the engine oil with an extta step being removal of the intake and battery box. I did not overflow as I only put whats supposed to be in there. Put almost 40k on the job and have had zero issues. Got all parts including oil from VW.
notovicrious is online now   Reply With Quote
Old 06-14-2018, 05:04 AM   #11
D2JML
whats your milege?
Old 06-14-2018, 08:22 AM   #12
Ik1015
Drives: mk5 ug
whats your milege?
~9,8000 miles. Wish keep until 150K, though.
