Old 05-29-2015, 11:57 AM   #1
erichorn10
Drives: 2010 2.5L Sportline.
Overfilled on Oil Change
Hi! So I did an oil change yesterday and overfilled by a bit. Half a litre at absolute most. In total I put 5.5L in, but it reads in the Max range on the dipstick. Should I be worried? Should I drain some? If I need to drain some, can I just drain the filter or will oil pour all over the place. I've never drained the filter with a full pan. Any help is appreciated.
erichorn10 is offline   Reply With Quote
Old 05-29-2015, 12:57 PM   #2
ashchuckton
FIA GT Newbie
ashchuckton's Avatar
Drives: 2013 GTI Base CSG DSG
I wouldn't worry about being .5 of quart over filled. That is just me, I'm sure there are others who will tell you to drain it out.
2013 GTI CSG 2 door Base DSG > Shultz
ashchuckton is offline   Reply With Quote
Old 05-30-2015, 10:05 AM   #3
erichorn10
Awesome! Thanks
Old 05-30-2015, 12:33 PM   #4
Irishbri
FIA GT Champion
Irishbri's Avatar
Drives: '12 GTI UGM 6MT 4dr
Is the oil filter on top or bottom of the engine? On the 2.0T its on top and the filters have a check valve so no worries....not sure about the 2.5....
FWIW I don't think an extra 0.5 liter will be a problem either. But any more than that I would err on the side of caution.....
*APR Stg 1+ * InJen Stg 1 CAI * South Bend Stage 3 Drop In * F Series TOB w/NLS Shims * BMS Clutch Stop * HPA 40% Short Shifter * Raceseng Slammer Engraved Shift Knob * HPA 75A Subframe Puck * Res Delete * 35% Tint Windows-20% Hatch* Black-Red Front Emblem * Blacked Out Rear Emblem & Badge * Yellow Lamin-X Fogs * Smoked Sidemarkers * Monster Mats * 3M Red Footwell effect * BT Dongle for TorquePro *
Irishbri is offline   Reply With Quote
Old 05-30-2015, 04:12 PM   #5
erichorn10
The filter is on the bottom, next to the oil pan. It has a release valve on the housing.
Old 05-30-2015, 10:11 PM   #6
BigDezzy
Oval Champion
Drives: 2012 MKVI GTI 6MT
You basically overfilled it by half a quart. I've overfilled an engine by half a quart in the past and nothing happened... thought once I found out about it I didn't like it. I'd monitor the oil and make sure that it's not whipped and foamy. You can get a cheap transfer pump (under $10) and pump it out from the oil dip stick tube. Obviously, I'd catch it back into a fresh oil can and reuse it later.
BigDezzy is offline   Reply With Quote
Old 05-31-2015, 01:37 AM   #7
MLue1
It probably won't do any damage but you know they put a dip stick for a reason and over filled engine can slow you down a the oil become the restriction. Just drain a bit using the valve on filter, that's the recommended way.
Old 05-31-2015, 02:43 AM   #8
DKhubs
DKhubs's Avatar
Drives: 2010 VW Golf
I imagine it might mess with the pcv valve on you valve cover, causing you to dump oil into your return. Gunking up your intake manifold and your MAP sensor throwing a premature P0106 and you might get oil on your coil packs.
I'm not an expert, so I may be wrong, I'm just taking a wild guess... /2cents
Golf MK6 base 5MT || ST Coilovers || Motegi 17X8 || ECS Tuning dogbone mount || Clean Trunk Mod
DKhubs is offline   Reply With Quote
Old 05-31-2015, 09:57 AM   #9
ashchuckton
FIA GT Newbie
I'd say as long as the oil isn't so overfilled that the crank counterweights are hitting the oil you'll be fine. If the crank is hitting the oil causing cavitation the oil level will need to be lowered. Is the oil foamy on the dipstick? If so lower the oil, if not don't worry.
Old 06-01-2015, 12:58 AM   #10
Golfn13
Drives: '13 5-spd blue graphite
I just did this last Saturday. I changed my own oil but put in 6 bottles and was in the max driving it for a week. Thinking that's perfectly fine and not reading the manual like I should have. I realized my mistake, called/went looking for a 1/8th vinyl tube to put down the dipstick and nobody had that size. I called dealer who said they could drain, but what I didn't know was they drain a little, not all of it like I thought.
Long story short - go by the book and drain it yourself. It's super easy to, no disassembly . Just loosen the plug and it doesn't come out until the screw is about to come off, and it's easy to regulate the flow. Now it reads in the middle like it should.
Golfn13 is offline   Reply With Quote
Old 06-01-2015, 11:13 AM   #11
erichorn10
Thanks a lot for all of the replies folks. No, the oil is not foamy on the dipstick and I have noticed zero change in driveability. If anything, I have better throttle response now. I may just drain some out just to ease my paranoid mind. So with that said....drain from the filter using the release plug, or buy a transfer pump? Sorry, I'm new at all of this.
Old 06-02-2015, 01:24 AM   #12
MLue1
... the release plug on the filter.
Old 06-02-2015, 01:44 AM   #13
Trnado_2.5
Formula 5000 Champion
Trnado_2.5's Avatar
Drives: A3 Quattro
Just drain the oil from the oil filter plug. Drain most the canister out and start the car. The canister will refill with oil and make the oil level a little lower. No point in taking out a ton of oil and having to refill.
But honestly, I wouldn't worry too much. It doesn't sound like you crazy over filled. If it really bugs you, like I said drain a little from the oil filter canister.
Trnado_2.5 is offline   Reply With Quote
