Old 10-22-2015, 07:19 PM   #3963
jettaglx91
Drives: 450whp TSI GTI, 420whp R, stock CC
Originally Posted by Rawradrian View Post
Thanks guys! Installed an 02 spacer and followed the steps on the last page and it passed! Now the new owner can enjoy it
It should work fine without spacers as well, I probably do it 2-3 times a weeks. When you did the end of line test what number on the counter were you stopping at?
jettaglx91 is offline   Reply With Quote
Old 10-22-2015, 07:26 PM   #3964
Rawradrian
Drives: 2011 cw gti
The shop that did it for me said it kept stopping at the oxygen sensor part. They couldn't get past it until they installed the spacer.
Instagram: @rawradrian
Build Thread
Rawradrian is offline   Reply With Quote
Old 10-22-2015, 07:48 PM   #3965
jettaglx91
Sounds like they didn't wait long enough, some take like 5 minutes on that one monitor
Old 12-07-2016, 08:59 PM   #3966
fender177
fender177's Avatar
Drives: White
Anyone know if there have been any updates beyond the K04 v3.1 tune? I was on APR's site and saw the Stage 1 & 2 tunes had a new ECU tune available. Just curious.
2011 Black GTI 5dr 6MT | APR K04 v3.1 ZOMG| APR TBE | South Bend Stage 2 Daily Silent Clutch | Carbonio Stage I CAI | Euro Short Shift Kit | ECS Dogbone Mount Insert
fender177 is offline   Reply With Quote
Old 12-07-2016, 11:58 PM   #3967
thatspsychotic
thatspsychotic's Avatar
The new Stage 1 and 2 tunes take some of what was developed for the K04 V3.1 (driveability, etc.) and applied it to the Stage 1 and 2 tunes, among several other things. Prior to 2.x, those tunes were like 7 years old and a lot had been learned.
APR Stage 2 v2.4, Carbonio, Cast Downpipe | PTP Turbo Blanket | GFB DV+ | Unibrace UB | Tyrolsport Deadset | BFI Stage 1 Mounts | SuperPro Offset LCA Bushings | Enkei Raijin Gunmetal 18x8 et45 | Michelin PSS 245/35R18
Old 12-15-2016, 01:28 AM   #3968
sovietsky19
Drives: CW MKV 09'
Any new changes to the Ko4 v3.1 tune? Havent been on here in a long time...
APR K04, APR Carbonio stage 1 & 2 intake, APR turbo back exhaust, S3 intercooler, Koni STR.T with H&R Sport springs, Neuspeed throttle pipe, AWE discharge pipe and hoses, BSH pendulum mount w/ autotech insert. RIP/TOTALED GTI
sovietsky19 is offline   Reply With Quote
Old 12-15-2016, 10:02 AM   #3969
Cryptic1911
Drives: 2008.5 GTI TSI
they have a v3.2, but it's the same as v3.1 but with the addition of no lift shifting, brake boost / left foot braking, and launch control if you choose them
Old 12-16-2016, 12:49 PM   #3970
sovietsky19
Drives: CW MKV 09'
Thanks for the update, i guess v3.1 is as high as they are going woth the k04.
Old 12-16-2016, 02:19 PM   #3971
charrigan
Drives: 2013 GLI
Arin stated months ago 3.1 maxes out the k04 and no more changes would be made.
2013 FIAT 500e
2013 GLI
2013 Audi Q5 2.0T
charrigan is offline   Reply With Quote
Old 10-21-2018, 05:43 PM   #3972
cons
cons's Avatar
Drives: Tiguan APR K04 + DQ500
Hello all! I waited a long time for APR DQ500 tcu upgrade, but no good luck. It seems to be no APR firmware upgrade in nearest future. Good news for me that other tuning companies have DQ500 firmware upgrades, but I don`t know how it will work with APR K04 3.1 software. Which launch RPM is the best for launch on APR 3.1 with AWD? What ideal shift points for use in D, S, M modes?
I found this posts https://www.golfmk6.com/forums/showp...postcount=3394 and https://www.golfmk6.com/forums/showt...90#post2006790 but there were FWD cars with DQ250 and I have AWD with DQ500.
2012 Tiguan 2.0T AWD APR K04 3.1, Mahle forged pistons, IE forged rods, Supertech valve springs, DQ500, APR Carbonio intake St1+2, APR IC, Neuspeed pipes, 3" downpipe (200cell Magnaflow cat+Vibrant resonator), RSQ3 catback with exhaust valve control, DV+, R8 coils, Denso IK01-24 spark plugs, PTP turboblanket, ECS oil catch can, Bilstein B6 Sport, ATE Ceramic.
cons is offline   Reply With Quote
Old 10-23-2018, 05:24 AM   #3973
cons
cons's Avatar
I made graphs for APR K04 3.1 and DQ500 in each gear revving to 7000 RPM:
My dyno:
WHP
Torque
Does it mean that ideal shift points are 7000rpm for 1th gear and 6750rpm for 2th and 6500 for others?
File Type: jpeg BB841B15-20FD-461E-8803-948B9751C297.jpeg (64.4 KB, 117 views)
File Type: jpeg 855DC64B-7287-4073-A7E1-E8E404F57A55.jpeg (62.8 KB, 111 views)
File Type: jpeg 61E28B64-381D-49CE-A214-22F59E15AE5D.jpeg (59.3 KB, 114 views)
Old 10-25-2018, 03:20 PM   #3974
kthor703
kthor703's Avatar
My dyno:
WHP
Torque
You are correct. I think APR posted somewhere that 1st gear is around 6750 rpm, and each subsequent gear is 250rpm less.
Edit: this was for the manual trans. Not sure how the DSG ratios differ.
Old 10-25-2018, 04:47 PM   #3975
cons
cons's Avatar
May be APR is right. If we take a closer look to graphs we will see this points:
1st: 6800 RPM (58kph)
2nd: 6500 RPM (90kph)
3rd: 6200 RPM (130kph)
4th: 6000 RPM (175kph)
5th: 5800 RPM (220kph)
File Type: jpeg 61E28B64-381D-49CE-A214-22F59E15AE5D.jpeg (92.4 KB, 92 views)
ie450 kit with dm tune, still sheeeeeeeeep
