Old 04-09-2018, 04:57 PM   #1
SteveInLA
SteveInLA's Avatar
Drives: 2011 VW GTI, CW w/DSG, Sunroof, Nav
DSG clutch pack upgrade recommendations needed
A K04 turbo, a limited slip differential and more track days are all in my car's future. If I am installing an LSD and know that the car will be coming close to the limits of the OEM transmission, does it make sense to upgrade the clutch pack at the same time? It looks like APR no longer makes their kit so are there any other recommendations? I don't see exceeding the specs for APR's K04 which is 375HP/408TQ on 100 octane.
SteveInLA is offline   Reply With Quote
Old 04-09-2018, 11:04 PM   #2
zef
Drives: 2013 GTI
I went through the same debacle with mine when I had my LSD done. APR still makes the DQ250 clutch packs for our cars but they're having software issues with certain box codes which is why they removed them for sale for the time being. For KO4 power levels all you need is good DSG software (HPA or APR). I wouldn't trust anyone else for proper DSG software. When my trans was pulled apart they said everything looked brand new even though it was a 70k mile (heavily abused but well maintained) transmission.
It's not really power that kills these transmissions...it's heat.
The only thing I can really recommend is looking at getting the bigger OEM DSG cooler off the TTRS (theres a link to it in my build thread). It's bigger than stock but still bolts into the same location. Alternatively, USRT sells a plate that replaces the DSG cooler and allows you to run an external cooler for better cooling capacity
http://www.usrallyteam.com/index.php...oducts_id=1908
Check out my build thread here -> Build Thread
Old 04-12-2018, 05:46 AM   #3
U-20T
Formula 3000 Champion
Drives: BT GTI4Motion
The urst plate won't work and the ttrs (dq500) cooler is completely different
U-20T is offline   Reply With Quote
Old 04-12-2018, 05:49 AM   #4
U-20T
A good DSG tune and potentially divorced cooling system, I have a trans pan ready to go with 8an bugs for a divorced pump style cooler and a usp cool flow filter housing and OEM brand new clutch cover I'll sell (PM me). I have a dq500 now.
A good dsg tune for racing will help eliminate slip which helps keep the temps down, it will not be as smooth though when you are just driving normal.
Old 04-12-2018, 01:48 PM   #5
zef
Drives: 2013 GTI
Maybe it's not off the TTRS then, but it's larger and it bolted right in without any modification.
Why won't the USRT plate work?
Old 04-12-2018, 05:00 PM   #6
U-20T
Pressure issues, that's why ssp uses a pump system
Old 05-12-2018, 01:09 AM   #7
MacRadiators
MacRadiators's Avatar
Drives: RS3 ,Leon FR
Check TVS engineering for clutch upgrade. They have no equals when it comes to dsg.
DSG plate with external oil cooler works just fine.
MacRadiators is offline   Reply With Quote
Old 05-28-2018, 08:26 AM   #8
Chris659
Touring Car Champion
Drives: 12 Beetle Turbo
Think youíre referring to the TT-S cooler thatís supposed to be larger and still got the dq250
Chris659 is offline   Reply With Quote
Old 06-06-2018, 05:34 PM   #9
BudgetPhoenix
Drives: 09 GLI
There used be chinese company selling giant factory fit coolers that were even taller than the TT 15 row coolers. They were like 20 rows or something.
Old 06-19-2018, 09:08 PM   #10
raphaelpmc
Drives: Fusca 2012 (Beetle)
Anyone have the VCDS protocol to calibrate de DSG ?
raphaelpmc is offline   Reply With Quote
Old 06-19-2018, 10:23 PM   #11
BudgetPhoenix
Drives: 09 GLI
This is the procedure
http://wiki.ross-tech.com/wiki/index...arbox_(DSG/02E)
Old 06-27-2018, 10:06 AM   #12
raphaelpmc
exactly ! Many friends are now using TVS tune and hardware when needed, they are all happy
Old 07-09-2018, 04:30 PM   #13
MacRadiators
I have the TVS stage 2 on the RS3 gearbox and it has no equals to be honest.
Expensive yes, but its better than anything i ever tried on the other dq500 and dl501 i have.
