Old 01-16-2013, 04:18 PM   #141
Thumper
Formula 3000 Driver
Thumper's Avatar
Drives: 15 Audi S3/'15 Audi S4/'15 328dx SW
Originally Posted by lilfleck View Post
What's wrong with reusing OEM parts? As someone else mentioned, it's based off the OEM design. I don't think a few OEM bolts are the cause or affecting disc failures...
Eactly, the OEM clutches are slipping not exploding. Before any blame for an aftermarket using a design based off the OEM causing issues is doled out there is one important factor that must be addressed which isn't.
What part of the OEM design is the flaw? Is it the pressure plate? The flywheel? The friction disc?
I've said it before and I will say it again and I will continue to say it; this issue does not have a simple 1 answer solution. If the weak point was the pressure plate then people putting in a drop in disc would not be getting results. If it is the flywheel then how come there are people who are keeping the OEM flywheel and not having problems??
And as always I revert back to the same statistical fact.......OEM clutches are not all failing at the same point and the same power levels. Stock car on stock clutch fails at 9000 miles meanwhile you could have a Stage 2 car running the stock clutch for 30,000 miles.
There is clearly more than one issue going on here and it goes past bolt and spring design.
2018 Audi TT-RS | Audi Exclusive Mexico Blue | Black Optics/Sport Pack | Tech Pack
2012 GTI 4dr Black Pearl 6spd w/Xenons - Check out my Build thread "The Wraith" - SOLD
Thumper is offline   Reply With Quote
Old 01-16-2013, 04:48 PM   #142
Mustache rash
Formula 5000 Champion
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Aftermarket clutch kits are oem but not for our application.
Again referencing this thread:
http://www.golfmk6.com/forums/showthread.php?t=33625
Stock disc have a floating spline carrier that can compensate for axial misalignment.
This is why the springs pop out.
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Mustache rash is offline   Reply With Quote
Old 01-16-2013, 05:32 PM   #143
XGC75
Formula 1 Driver
XGC75's Avatar
Drives: into shit
You said earlier that where one supplier might be faulty (ie southbend), if the other supplier uses the same design methodology (borrow from OEM) then it should be put under the same scrutiny. I think this is a key issue.
Any clutch gurus out there (Dave or Mike) care to comment on specific design features that might differentiate a particular product? For example, if it is the spline carrier that fails in Southend (pre-revision) units, how does your product do it better?
butchered by autocorrect
XGC75 is offline   Reply With Quote
Old 01-16-2013, 05:44 PM   #144
lilfleck
Moderator
Drives: '11 GTI Autobahn, DSG
Thicker springs should stay in there better. More support around the edges perhaps.
CM FX350:
Southbend Stage 2 Daily:
Revised Southbend Disc by Exedy:
SACHS OEM+ (the way it should be IMO):
lilfleck is offline   Reply With Quote
Old 01-16-2013, 05:47 PM   #145
lilfleck
Moderator
Added that info to my thread on my clutch research:
http://www.golfmk6.com/forums/showthread.php?t=52388
Old 01-16-2013, 05:50 PM   #146
MaliciousMK6
Formula 3000 Driver
MaliciousMK6's Avatar
Drives: 2011 Tornado Red 2Dr 6MT GTI
Good info!
MaliciousMK6 is offline   Reply With Quote
Old 01-16-2013, 05:51 PM   #147
realcyberbob
realcyberbob's Avatar
Drives: 2011 GTI
Send a message via AIM to realcyberbob
Stock clutch disc for reference:
I have more pictures of the stock setup in my thread as well: http://www.golfmk6.com/forums/showthread.php?t=51717
2011 CW GTI 6-Speed: APR Stage II, APR Carbonio Intake, Clutch Masters FX350 Clutch Kit, 42nd Draft Designs Downpipe, Magnaflow Catback Exhaust, Forge Twintercooler, BFG DV+, Dieselgeek Short Shifter, ECS Dogbone Mount Insert, StopTech Pads & Slotted Rotors, Tyrolsport Brake Stiffening Kit, Golf R LED Tail Lights, CiM Vent Boost Gauge, RNS-510 Navigation, Uber-Stealth Box & 10" Pioneer Sub, Alpine MRP-M500 Amp, 25th Ann. GTI Golfball Shift Knob, Modshack Low Profile Engine Bay Trim, Hankook V12
realcyberbob is offline   Reply With Quote
Old 01-16-2013, 05:52 PM   #148
APRMK6GTi
APRMK6GTi's Avatar
Drives: 2012 GTI
man those are some beefy springs in the SACHS OEM+
2012 CSG GTI 6SPD | APR Tuned | AWE K04 | APR Carbonio | IE FDS IC | 42DD DP | Magnaflow CBE | Neuspeed TOP/ACP | GFB DV+ | DG S6 | Fluidampr| OEM MSB | Verdict SBB | HST RSR | ECS Bleeder Block | SuperPro LCA/ALK | 034 TAI | AST/GC | OZ | ST40| Whiteline 24MM F&R | Tyrolsport | Unibrace XB/UB/RB | EuroSport LB | Euro OEM LED | OEM Aero | P3 |
Nor Cal VW Drivers Club
Old 01-16-2013, 05:56 PM   #149
lilfleck
Moderator
No lie... you know its solid quality. It's just not very affordable.
Old 01-16-2013, 05:59 PM   #150
Mustache rash
Wow this thread just got good!!!!!!
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 01-16-2013, 06:13 PM   #151
lilfleck
Moderator
FWIW, I have taken all the interesting bits that I have found on this forum on clutches and put it in the OP of this thread, http://www.golfmk6.com/forums/showthread.php?t=52388
Old 01-16-2013, 06:24 PM   #152
APRMK6GTi
APRMK6GTi's Avatar
Drives: 2012 GTI
how much does the OEM Sach+ go for? Is it like $1600+?
Old 01-16-2013, 06:29 PM   #153
lilfleck
Moderator
1800+shipping i think.
Old 01-16-2013, 06:31 PM   #154
APRMK6GTi
APRMK6GTi's Avatar
Drives: 2012 GTI
o crap, that is expensive....+ install thats over 2gs
