Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Technical Topics > TDI / GTD discussions
Old 05-01-2019, 08:37 AM   #1
jimbobf
Drives: 2010 Mk6 1.6 Tdi
Injector issue or something else?
Hi,
alongside some other issues I'm trying to get a general sense as to whether the issues I've been having recently are due to the injectors.
Basically I get a very rough cold idle until the engine has warmed up (noisy, jumpy), which smooths out after a while. The engine also seems a little noisier than before (particularly when accelerating harder) which sounds to me a bit like slight misfire.
Its a 2010 Mk6 1.6 TDI - 116k miles.
No error codes at all from VCDS or lights on dash.
I had a look on VCDS and these are the readings, do they look normal?
I've noticed the noise and roughness getting worse recently.
injector 1 0.5096 mg/stroke
injector 2 -0.1097 mg/stroke
injector 3 -0.2507 mg/stroke
injector 4 -0.1664 mg/stroke
this was an roughly average over 3/4 different readings.
When revving they were all around 0-ish as expected.
I know I've got clutch judder and its on the original DMF but don't think that would attribute to the engine noise and rough running?
Does injector 1 look ok? I'd almost like it not to be - just so I know what to try.
thanks!!
Jimmy
jimbobf is offline   Reply With Quote
Old 05-08-2019, 01:21 PM   #2
jimbobf
Hi, has anybody got any ideas? Thanks again
Old 05-09-2019, 07:09 PM   #3
Formula 2 Driver
zrickety's Avatar
I don't know much about the TDI, but if you have a cam magnet like the GTI I would suspect that or sticking plates inside the cam.
Originally Posted by DASVDUB View Post
Get all mods done pre marriage.
Old 05-19-2019, 03:43 PM   #4
Gttdi140ez
Newbie
Gttdi140ez's Avatar
Drives:
My mate whos a mechanic told me to avoid the 1.6tdi when I was looking for a diesel golf last year. He said the 1.6tdi is notorious for having injector issues. I think he said its due to the brand of injector that was used on the 1.6 that is the problem.
Gttdi140ez is offline   Reply With Quote
