Old 05-20-2019, 01:35 PM   #1
Bushido
Drives: 14' CSG GTI Wolfburg Edition 6MT
ECS Tuning Stage 2 Clutch Kit
I'm anticipating a clutch upgrade in the near future once my clutch start going, and I see that ECS Tuning has a Stage 2 Clutch kit out now. The price point seems almost too good to be true. Anyone have experience with these yet? Or can anyone give their 2 cents on if this seems like a good option given the specs they are putting out there? It looks very similar to a BFI, except the pressure plate is 1,685 lbs instead of 2,500 lbs.
https://www.ecstuning.com/b-ecs-part...003465ecs01kt/
MK6 CSG GTI Wolfsburg Edition 6MT | APR Stage 1 ECU | APR Stage 1 & 2 Carbonio Intake | APR Catback Exhaust | APR Boost Tap & Boost Gauge | ECS Turbo Outlet Pipe | ECS Intake Pipe | GFB DV+ | R8 Coil Packs | H&R Sport Springs
Bushido is offline   Reply With Quote
Old 05-20-2019, 03:23 PM   #2
torga
FIA GT Champion
torga's Avatar
Drives: '11 GTI - 6MT - 2dr
Huh. BFI's Stage 1 is 1900lb and is only rated to hold 290lb-ft, while their Stage 2 2500lb plate holds 400lb-ft.
I wonder how ECS is managing to hold 400 with a 1685lb plate. The numbers don't really add up. Does anyone know what Southbend's Stage 2 plate is rated for? Southbend and BFI are the two kits I see recommended most around here.
Build Thread
Major/Notable Mods ||| Engine/Drivetrain: GIAC Stage 2, APR Cast DP, Beluga CBE, BSH mounts, BSH CAI, DG Sigma 6 SSK, Fluidampr Pulley, GFB DV+, Neuspeed charge pipes Suspension: FK Streetline-X coils, H&R rear ARB, Rotiform RSE Exterior/Interior: R20 Euro tails, BFI knob, RCD330+ ||| full mod list
torga is offline   Reply With Quote
Old 05-20-2019, 05:44 PM   #3
Allchokedup
FIA World Rally Car Newbie
Drives: 2011 ko4
Southbend daily is rated "conservatively "@ 400ftlbs.
I run one with apr ko4 for about 10k miles now holding up great
2011 2 door, ko4,apr 2+,fmic,custom intake(bootleg) redtops, VMR810 198.5
PS4s,some other stuff..
Allchokedup is offline   Reply With Quote
Old 05-20-2019, 05:55 PM   #4
torga
FIA GT Champion
torga's Avatar
I meant the pressure plate. The only numbers Southbend publishes are the 400lb-ft rating and a 12,000rpm burst point.
Build Thread
Old 05-20-2019, 09:34 PM   #5
Allchokedup
Drives: 2011 ko4
Sorry, skipped that part! I would assume surface area and type of material used. I just had mine apart and the disk was in great shape.
Old 05-22-2019, 08:55 AM   #6
Bushido
If the pressure plate was too much on the light side, what would the consequences of that be? clutch slip and low lifespan?
Old 05-22-2019, 12:32 PM   #7
ECS Tuning
Formula 3000 Driver
ECS Tuning's Avatar
Drives: Modified ones
Our disc is an organic woven friction face, thanks to our material choice were able to use a lower clamping load. This clutch kit is installed in our MK7 GTI, she put down 370 ft/lbs to the wheels (so using meh math ~425 at the crank). I tried to make it slip and wasn't successful, even after using the car as a learning car for a new stick driver (riding the fire out of the clutch), jumping in it's still solid. Stack on top of that the road trip from ECS to EuEx and a lot of fun back roads, going out to the car today still zero sign of slip.
-James
ECS Tuning your #1 source for all things German automotive
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
sales@ecstuning.com | customerservice@ecstuning.com
ECS Tuning is offline   Reply With Quote
Old 05-22-2019, 06:35 PM   #8
Bushido
-James
James, great to hear from you guys directly! I appreciate the background on the product and usage.
Sent from my SM-G965U using Tapatalk
Old 05-22-2019, 07:21 PM   #9
torga
FIA GT Champion
torga's Avatar
-James
Does the included Luk TOB match the plastic OE spec or the revised, metal OE spec?
Build Thread
