Old 10-17-2018, 06:25 PM   #15
somerset9
Rally Car Champion
somerset9's Avatar
Drives: 2007 GTI 6MT
Originally Posted by Short Bus View Post
Looks good, congrats!
Thanks! I'm actually reading up on your TT-RS control arm busying DIY, another thing on my to-do list. I don't know why VW went with the softer bushings for the GTI, couldn't have been that much cheaper over the S3/TT-RS parts.
somerset9 is offline   Reply With Quote
Old 10-17-2018, 11:10 PM   #16
Blakcard
FIA GT Champion
Blakcard's Avatar
Originally Posted by somerset9 View Post
The TSI makes maybe 10 lb-ft, 10 bhp at most over the FSI engine...not sure where that comment is coming from. I didn't buy it for speed, there are faster cars at the price, of which the mk6 isn't one of them.
Like I said.. just kidding. I'm happy you bought what was right for you. Was just light hearted humor so go easy
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GFB DV
Old 10-18-2018, 03:32 PM   #17
Short Bus
FIA GT Champion
Short Bus's Avatar
Drives: CW '10 GTI, 6MT
I really can't recommend that upgrade enough, it's fantastic. In hindsight if I could recommend approaching it any differently I would seriously consider just removing the entire control arm, which should make getting the bushing in place over the control arm a lot easier than the method I used. I was trying to be lazy and not have to remove the wheels and I think it ended up taking a lot more effort.
Short Bus is offline   Reply With Quote
Old 10-19-2018, 09:32 AM   #18
Tony48
Tony48's Avatar
Drives: 2011 GTI / K04 / 6MT
Just a quick FYI...Dropping the control arms is easy if you have a manual trans. Apparently if you are DSG it's a huge PITA to remove the front control arm bolt on the trans side. The DSG trans housing is larger than 6MT and prevents you from pulling that bolt foward and out of the subframe. To gain the clearance needed to remove the bolt you have to disconnect the trans mount (maybe also the dogbone mount) and lift the engine/trans up a bit.
Also worth noting that this bolt is a TTY bolt and should be replaced. Part #n10141003.
This is the offending bolt:
IMG_20180808_223709 by Tony G, on Flickr
| 2011 GTI - P&P K04 - Stratified ProTune | Build Thread| Timing Chain Replacement Tips | DIY RSR Clutch & RMS Replacement Tips|
Old 10-19-2018, 12:53 PM   #19
Short Bus
FIA GT Champion
Short Bus's Avatar
Ahhh right, thanks for that. I remember reading about that bolt on DSG cars a while ago but it had slipped my mind.
