Old 05-08-2018, 02:41 PM   #1
kenveen21
Drives: 2010 Volkswagen GTI
Mark 6 GTI timing chain tensioner
Hello again all! as posted late last year, my car recently suffered a major timing chain tensioner malfunction. This caused four of the valves to bend in the engine and the total cost to be around $2500.
My question here is what should I do with the car? I purchased the vehicle for around 6000 last summer but funds are very tight right now die to the repair bill. Should i keep the car and still use it or should i sell the car for something a little cheaper and more reliable until i am able to afford owning a GTI again? any thoughts are helpful. Thanks guys!
kenveen21 is offline   Reply With Quote
Old 05-08-2018, 03:14 PM   #2
Tifore
Oval Newbie
Drives: 2012 Black 6MT GTI
Did you get it fixed or you still are faced with the bill of $2500?
Tifore is offline   Reply With Quote
Old 05-08-2018, 03:28 PM   #3
kenveen21
i am getting it fixed currently so it is too late to sell it as is
Old 05-08-2018, 03:33 PM   #4
cchase__
Oval Newbie
Drives: Shadow Blue Metallic MK6 GTI 2 Door
Does the timing chain failure just affect the valves? Can you order a set of new valves and you're good? If so I'd honestly buy new valves ($200) and some forged con rods and heads lol
cchase__ is offline   Reply With Quote
Old 05-09-2018, 09:26 AM   #5
Formula 2 Driver
zrickety's Avatar
Sounds like you got a good deal on the car. Assuming it's fixed properly, you should be able to drive it for many more years. You'll be hard pressed to find a better car for the money.
Old 05-15-2018, 08:20 PM   #6
BS2H
Touring Car Newbie
BS2H's Avatar
Drives: 2011 UG GTI BS2H
**UPDATE**
Confirmed timing chain failure - engine is fried / totaled. I'll need a new engine replacement or I can scrap this car for parts. Was offered $6,600 BEFORE the engine died, so looking at a couple of thousand bucks for the car right now. Ridiculous.
Insurance will not help because it's a mechanical malfunction. So I'm SOL.
Any suggestions?
Don't mean to threadjack, but it seems OP issue is satisfied?
Hey guys,
I have approx. 90,000 miles on my car.
So today I tried to start my car and it turns over (Battery is ok, spark plugs were changed at 60k, so they are ok.
But the car doesn't start up. I'm thinking 1) there is a boost leak somewhere (PVC?) or 2) timing chain went and the injectors are bent which means that there is no compression in the cylinders. It just clicks and clicks and clicks until I turn the key off.
My question is - how did you know if your timing chain went? Does this sound like mine has gone? And thanks for the response - I'll probably be looking at 1,100 to 1,400 I guess. Why was yours $2,500? Was this at the VW dealer or specialized dealer?
BS2H is offline   Reply With Quote
