Old 03-21-2016, 12:28 PM   #29
CFG9000
Drives: 2012 GTI Autobahn
If you actually have some sort of a problem with the factory ECU, get the update. If not, don't get it.
So do we need it to update our Stage 2 tune or not?
2012 Volkswagen GTI Autobahn
Color: Black / Gearbox: DSG / Style: 5-door
Mileage: 25000mi / Status: APR Stage 2 (Carbonio/DP/ECU)
Other Stuff: 3M 35% tint all-around - Maniacs shift paddles
CFG9000 is offline   Reply With Quote
Old 03-21-2016, 12:28 PM   #30
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
Originally Posted by Paytrose View Post
What does this mean? Box code? Is that a ECU model number?
Yes. If you know the code, you can double check it's ready right this second.
Old 03-21-2016, 12:28 PM   #31
Arin@APR
Arin@APR's Avatar
No
Old 03-21-2016, 12:31 PM   #32
Paytrose
Paytrose's Avatar
Drives: 2014 GTI Drivers Edition
Awesome. Confirmed with the APR dealer that my box code was listed. Scheduled Friday to get it updated. Will update ASAP.
2014 Black Pearl Metallic GTI Driver's Edition | Serron Wheels | HS Tuning RSR Clutch | 42DD TBE | APR Stage 2 (93 Oct V2.4) | Conti DWS06 | DEPO LED Tail Lights (Dark Cherry) w/ DeAutoKey Reverse LEDs | Neuspeed P-Flo CAI w/ AEM Filter | R8 Coils | Raceseng Ashiko Shift Knob | 25% Tint | RokBlokz Mud Flaps | S3 Short Shifter | I Need More...
Paytrose is offline   Reply With Quote
Old 03-21-2016, 12:35 PM   #33
Arin@APR
Arin@APR's Avatar
Originally Posted by corydd View Post
Does the new update include torque by gear?
Yes! Added: "torque-by-gear helps with traction control and protects the engine from being lugged out in tall gears" to the APR difference above.
Old 03-21-2016, 12:36 PM   #34
RudolphTheRedNosedGTI
Drives: Mk6 GTI DE K04 6MT
Arin, is the launch control system a spark cut only or does it cut fuel as well? (i.e. can I shoot flames?)
RudolphTheRedNosedGTI is offline   Reply With Quote
Old 03-21-2016, 12:47 PM   #35
blingdub
Drives: 2011 GTI MK6 Autobahn MT, Uni 1+
wow...seriously impressive. almost stage 2 numbers with stage 1.
VW '11 GTI Autobahn MT, Unitronic Stage 1+, ECS Luft-Technik Intake, RevD DV, R8 Coil Packs
SPULEN Quick Change Short Shifter Kit, Torque Solution Shifter Cable Bushings, ECS Shifter Bracket Bushings, Raceseng Ashiko
Red LED Footwell Lights, Clutch Stop
blingdub is offline   Reply With Quote
Old 03-21-2016, 01:00 PM   #36
Arin@APR
Arin@APR's Avatar
Clean, so it cuts fuel. Spark is dirty and dangerous. It's cool, but we don't want you blowing your turbo and catalyst to bits.
Our LC is also fully adjustable - You set the launch RPM with the throttle and brake pedal. You're not locked into one setting.
Our LC also builds boost - Give it more throttle, and you get more boost. Give it less throttle and get less boost.
Old 03-21-2016, 01:01 PM   #37
Arin@APR
Arin@APR's Avatar
Originally Posted by xd-data-ii View Post
1K0907115AT S0040 not available yet.
Any chance it would be by Wednesday afternoon?
Have your dealer put in a request and we'll email him when it's ready.
Old 03-21-2016, 01:11 PM   #38
ROOSTER1050
ROOSTER1050's Avatar
Drives: MKVI CW GTI K04DR -DSG
I'm confused...... So, wut about K04??
I've been v2. Something for k04 fit a couple years now, files tested on the track at fastivus before finalized in fact ....... these would not apply for me, yeah?
SPM DP/SPM CBE track/street/CTS K04+APR V3.1C/APR DSG tune/UNITRONIC intake/VWR springs/Koni Yellows/UNIBRACE UB+RB+XB/Neuspeed FMIC/VMR V810/034 mounts/APR F+R SB/Neuspeed Charge&TO pipes/LED tails w-fog/GFB DV+/P3 gauge/Whiteline-A.L.K.+ end links/R8 coils/TT-RS Brembos/Neuspeed pulley
ROOSTER1050 is offline   Reply With Quote
Old 03-21-2016, 01:13 PM   #39
Arin@APR
Arin@APR's Avatar
You have version 3.1 per your sig, which is the latest and greatest. The Stage 1, 1+ and 2 files were never updated (6 years old or so). They are now updated too.
Old 03-21-2016, 01:19 PM   #40
Ronnie_B
Drives: 2013 GTI 4DR Wolfsburg 6MT
Just to clarify, do the torque limited tunes have approximately the same torque values as the old version 1 files?
I have a stock clutch, so I would like smoother power delivery throughout the power band, but not necessarily more peak torque than my current Stage 1tune delivers.
Also, is the torque by gears a new feature?
Thanks!
APR Stage 2 v2.4 93 tune, APR Cast Downpipe, DIY RSR Clutch, Peloquin LSD, iABED RMS, Carbonio Intake, Diesel Geek Sigma 6, DG manual springs, Koni Yellows, SuperPro ALK / RCA ball joints/ end links, H&R 26mm/24mm swaybars, ECS Subframe collar kit, G-LOC GS-1 / R8 Pads, Centric Blank Rotors, TS Brake Bushing Kit, Castrol SRF fluid, Yokohama AD08R's on OZ 17" Omnia (Track), Michelin Pilot Sport A/S 3 on Serrons(Street) Build Thread
Ronnie_B is offline   Reply With Quote
Old 03-21-2016, 01:24 PM   #41
Arin@APR
Arin@APR's Avatar
More or less. It's far different from the old file, but still basically around the same "peak" value, so to speak. We're offering a flat torque curve. There's some variance between octane and stage, but the goal was to keep it under 290 wheel on our dyno.
Basically, here is wheel torque:
277 WFT-LBS - STG 1 91 - Low
280 WFT-LBS - STG 1 91 w/ Intake - Low
288 WFT-LBS - STG 2 91 w/ Intake and DP - Low
285 WFT-LBS - STG 1 93 - Low
285 WFT-LBS - STG 1 93 w/ Intake - Low
289 WFT-LBS - STG 2 93 w/ Intake and DP - Low
Low output tune is the one you should get.
Thanks!
Yes!
Old 03-21-2016, 01:32 PM   #42
ROOSTER1050
Ahhh thank you 😂
Yes 3.x ....I have fat fingers ✌
