Old 02-25-2019, 05:24 PM   #15
torga
torga's Avatar
Drives: '11 GTI - 6MT - 2dr
I'm envious that you have access to machine tools. I worked at a machine shop for a while in college and man, I could do anything after work!
Did you have a dogbone insert before moving to the full mount? I'm wondering what your take on NVH is after the install.
torga is offline   Reply With Quote
Old 02-25-2019, 05:51 PM   #16
NewGuy
NewGuy's Avatar
Drives: 2011 GTI - 5dr - DSG
Yea shop access helps tremendously when dealing with slightly ill fitted parts.
I did not have a dogbone insert before, did not want to risk pairing it with my worn mounts.
That being said I cannot comment on NVH.
I changed my engine/trans mounts a week ago and that was noticeable increase in Noise, not so much Vibration and harshness.
But since this round I changed struts, springs, and the pendulum mount it is actually less NVH than before.
Probably because my struts were pretty worn and caused a lot of road NVH.
Current Setup: https://www.golfmk6.com/forums/showthread.php?t=118353
NewGuy is offline   Reply With Quote
Old 02-26-2019, 11:26 PM   #17
NewGuy
NewGuy's Avatar
Replaced my scuffed up emergency brake handle.
Got cheap one off eBay, surprised by the initial quality.
Not identical to stock one but actually seems more matched with other interior items like the soft touch surfaces.
Handle is a bit softer than stock as well.
Comparison images below.
New one on right
Installed
Old 03-14-2019, 07:55 PM   #18
NewGuy
NewGuy's Avatar
Removed MDi center console and replaced it with one with no MDi.
Required me to replace the air duct to the rear as well.
New center:
New air duct:
Old 03-14-2019, 07:57 PM   #19
NewGuy
NewGuy's Avatar
Had to open up my gauge to clean this out
Seemed like it was a water stain.
Not quite sure how or when it got in there but easy enough to open and clean.
Old 03-14-2019, 08:00 PM   #20
NewGuy
NewGuy's Avatar
Added some rice to the car with some carbon mirror covers.
Since its the cheap stuff it weighs more than the stock covers lol.
Did it so I could have some matching carbon parts.
I'll be adding a real carbon fiber spoiler to the car soon, just fixing some surface scratches and cracks first.
Got it for quite a good price.
Worst case scenario I'll just paint over the carbon if I dont like.
Old 03-14-2019, 08:19 PM   #21
Cadubya
“DUBYA” VP COUCH MOD
Cadubya's Avatar
New center:
Attachment 58481
New air duct:
Attachment 58482
Attachment 58483
Attachment 58484
Attachment 58485
Attachment 58486
Do you have all the part numbers for this?
CLICK HERE FOR MY BUILD
Old 03-14-2019, 08:22 PM   #22
whitewolf33
whitewolf33's Avatar
Drives: 2013 CW Wolfsburg
Attachment 58487
Attachment 58488
How did you open it?
Center console looks awesome
Old 03-15-2019, 01:29 AM   #23
NewGuy
NewGuy's Avatar
Center console:
1K0863323R82
Air duct:
1K0864255C
Old 03-15-2019, 01:31 AM   #24
NewGuy
NewGuy's Avatar
Pull trim piece above steering wheel and gauge.
Remove two screws, then the gauge cluster comes out.
Once out unplug from back.
To open it’s just 4 screws in the back.
I believe they’re t10s.
Old 03-15-2019, 07:53 AM   #25
Cadubya
Cadubya's Avatar
Center console:
1K0863323R82
Air duct:
1K0864255C
Thanks! Where’d you order them from?
Old 03-15-2019, 11:18 AM   #26
NewGuy
NewGuy's Avatar
I got the center console from ECS and the vent from dealership.
Honestly should’ve just bought both from dealership as ECS sent wrong one initially.
Center should be about $100 and vent $50
Old 03-21-2019, 08:39 PM   #27
NewGuy
NewGuy's Avatar
Added my carbon fiber spoiler that I repaired some cracks and scratches.
Fitment is decent, it lays entirely over the git spoiler and lifts up a bit too much near front top corners but not a big deal for me.
Now Removed because of unsatisfactory fitment, will try to reseat later. From the limited time on my car a new crack has appeared. Will be reinforcing the front lip with epoxy to ensure no new cracks develop when I reinstall.
Old 04-12-2019, 02:53 PM   #28
NewGuy
NewGuy's Avatar
Put some new wheels on her couple days ago.
No more running a mismatched set and trying to paint aha.
Going to be upgrading front sway bar, front control arm bushings, and installing lower subframe deadset kit this weekend.
