Old 06-04-2019, 09:48 PM   #1
Sgonzalez90
Drives: GTI
[Help] Replaced spark plugs and coils. White smoke came from exhaust
I had the coil 1 misfire fault code, and I replaced the spark plugs and coils accordingly. Drove the car around for a couple miles. Went to pickup oil to top it off. Drove half a block and oil started blowing out the exhaust. White smoke. Had to have the car towed. Got the wrench symbol, but only an unknown fault code! I'm being told that it maybe due to the PCV valve. The car is a 2013 GTI, at about 152k miles. I know the PCV valves are a common failure component and it has never been replaced. Could this be the issue? Should I DIY?
Just want my car back on the road!
Help :/
Sgonzalez90 is offline   Reply With Quote
Old 06-04-2019, 09:51 PM   #2
Boscogn
Boscogn's Avatar
Drives: CSG 2013 GTI DSG 4DR
White smoke is water burning not oil. Else it would've been blue smoke. Hard to imagine all that happening from just changing oil, plugs and coils.
Wish List: Golf R InterCooler | 034 Motorsports RSB
Old 06-04-2019, 09:54 PM   #3
Sgonzalez90
Drives: GTI
Also I checked my coolant levels and they were fine. Did not smell sweet. More so a burnt, harsh smell.
Old 06-04-2019, 10:07 PM   #4
BudgetPhoenix
Drives: 09 GLI
This happened to me a few months ago. I had a single misfire code with tons of white smoke out of the exhaust with strong fuel odor and very rough running engine. Tried swapping plug and coil first. Didnt work, looked inside and saw cylinder and spark plug were wet with fuel. Injector had failed and stuck open. Had to remove intake manifold and put in a new injector. Check to see what your plug tip looks like and if you can see any fuel on it or inside the cylinder.
Old 06-04-2019, 10:10 PM   #5
BudgetPhoenix
Drives: 09 GLI
I think the white/blue/black smoke thing is kind of subjective and maybe depends on what the lighting is like when you see the smoke. My issue was def a thick white smoke which turned out to be fuel dumping into the cylinder.
Old 06-04-2019, 11:09 PM   #6
SELA_MK6GTI
SELA_MK6GTI's Avatar
Are you dsg? When I had the wrench symbol pop up it was because of my dsg transmission. You arenít leaking any oil from the rear main seal or anything right? Hopefully itís not that but thatís just from my experience
Old 06-04-2019, 11:18 PM   #7
Sgonzalez90
Drives: GTI
Here is a photo
Old 06-04-2019, 11:19 PM   #8
Sgonzalez90
Drives: GTI
Yes DSG. How do I verify if there is a leak here? I haven't found any leaks tbh.
Old 06-04-2019, 11:21 PM   #9
SELA_MK6GTI
Mine was leaking from the rear main seal thatís how I saw mine, very small leak that drained the dsg fluid through time. But I donít think that would be the cause of the smoke issue. Hopefully itís like other guys said about the injector being open
Old 06-04-2019, 11:24 PM   #10
BudgetPhoenix
Drives: 09 GLI
Wait, a rear main seal keeps motor oil in the engine. The DSG fluid is encased in the transmission housing and the clutch packs are a sealed unit, there's no oil between them.
Old 06-05-2019, 02:53 AM   #11
SELA_MK6GTI
Gotcha, thatís just what I was told. I probably didnít remember the exact words correctly my mistake
Old 06-05-2019, 01:11 PM   #12
Sgonzalez90
Drives: GTI
Hey guys any ideas on what I should do?
Old 06-06-2019, 09:23 AM   #13
BudgetPhoenix
Drives: 09 GLI
Whats the code?
Old 06-10-2019, 12:55 PM   #14
NoNameBoy
That also happened to my GTI with same exact problem almost 2 years ago. Dealer replaced everything and a few weeks later check engine light came up again due to a bad cat. Dealer replaced too under the warranty
NoNameBoy is offline   Reply With Quote
