Old 10-13-2017, 04:10 PM   #1
henryjye
How long have you had your K04 ? Issues ?Solutions?
Wonder how long till all these issues pop up
Possible causes and solution for oil leaks ,Shaft play and etc ?
Sent from my MHA-L29 using Tapatalk
henryjye is offline   Reply With Quote
Old 10-13-2017, 05:01 PM   #2
FriggenT
The k04 is a workhorse....its been in many, many cars and the failure rate imo is not a high one. It's a Borg Warner turbo who's one of the best manufacturers out there.
You're much more likely to experience other car issues from the added power...motor mounts should be upgraded, ic will be beyond stock capacity, pcv might blow if you don't have the newest revision or a CC.
The turbo itself is rock solid keep your oil fresh and imo use rotella t6, if not, keep it changed every 3k with other oils.
Old 10-15-2017, 06:45 PM   #3
SnailPower
SnailPower's Avatar
Well considering my K03 went at 37k miles, I can't imagine the K04 any worse, lol.
Internal : APR Stage 2+ tune - Soundaktor Delete - Diesel Geek Sigma 6 Short Shifter - R8 Coils - ECS Dogbone Mount Insert - GFB DV+ - NGP Type I Coilovers - KMD Tuning Front Stress Bar - WhiteLine Endlinks - IE CAI - IE K04 - EuroJet DP - Magna Flow Exhaust
External : H8 Pure Yellow Fog Bulbs - 20% All Around Tints - ECS JOM Euro Style Badgeless Grille
Old 10-15-2017, 08:27 PM   #4
FriggenT
Is the k03 even a BW turbo?
Old 10-16-2017, 01:20 AM   #5
LightningRhod
LightningRhod's Avatar
Drives: 2011 CW GTI DSG
I believe the KO3 is an IHI turbo. Mine has been going strong for 173k miles, no failures
Old 10-17-2017, 12:10 PM   #6
kthor703
kthor703's Avatar
K03 is Borgwarner. TSI motors do not have K03s. TSI motors have an IHI model that is similar as I understand it.
Old 10-17-2017, 12:30 PM   #7
FriggenT
Yes, that's true....everyone just tends to call them k03, but yes... ihi
Old 10-17-2017, 12:38 PM   #8
What do you mean 'all these issues...' There are a number of K04 cars going 100k or more without a problem. Mine has 140k.
Old 10-17-2017, 12:53 PM   #9
corrado917
corrado917's Avatar
Drives: GTI CSG
It depends, mine is still fine. Got it installed around 70K miles (APR kit), car has 145K miles & no issues, mostly highway driving (daily), plus long road trips.
Old 10-18-2017, 06:18 AM   #10
henryjye
good to know u guys have put it on for so long and it almost last forever
was thinking whether i should keep plenty budget to fix it if it fails
