Old Yesterday, 12:00 PM   #44353
DASVDUB
DASVDUB's Avatar
Originally Posted by franco516 View Post
the PCV came with a new gasket.
Fresh spark plugs and coil packs? Any CELís? Bad tank of gas?
2dr 2011 Candy White GTI|APR Stage 2|Godspeed catless dp|custom straight pipe catback|Carbonio Stage 1 & 2|Forge Diverter Valve|H&R Super Sports|Koni Orange Struts & Shocks|R8 Coils|NGK BKR7EIX Plugs|Soundaktor delete|20% tint|
Old Yesterday, 12:03 PM   #44354
uglybastard
uglybastard's Avatar
Drives: VW Mk6 GTI 3 pedal in CSG; Jeep WJ
my initial thought is that this might not be seated entirely - as the engine heats up the gasket expands into place.
other thought is what was being alluded to before, with the old rebreather hose that connects just above the turbo at the intake pipe. if mis-seated there, you'd see weird starts. work rechecking that seating and as a consequence, confirming all the hose connections to the PCV.
also normal RPM at idle after warmup phase for me on stock tune was ~ 1000rpm. tunes you could see as low as 700rpm, varies by tuner.
..246.............. Insta
Old Yesterday, 12:07 PM   #44355
franco516
franco516's Avatar
Drives: gti
plugs should be good since i changed them when i went k04 over the summer, no issues since then so i doubt it. bad gas? maybe..
i will look into that intake hose connection later, thanks for the advice.
IG - @francotirador91
Old Yesterday, 04:10 PM   #44356
franco516
franco516's Avatar
Drives: gti
hoses seemed to be ok but i bought two new hoses just incase
Old Yesterday, 10:20 PM   #44357
DASVDUB
DASVDUB's Avatar
When was the last time you filled up?
Old Today, 01:39 PM   #44358
franco516
franco516's Avatar
Drives: gti
before installing the new pcv. its deff not the gas.
Old Today, 02:53 PM   #44359
Blakcard
Blakcard's Avatar
is there even a way to check the diaphragm on the new PCV before you installed? can you check it now? make sure the spring etc is seated correctly?
by the time you've read this, I'd have already done.....this > Mostly stock, APR stage 1 2.4 file, Stoptech rotors, GFB DV
Old Today, 04:57 PM   #44360
franco516
franco516's Avatar
Drives: gti
id have to remove it. i had the dude at the shop install it. i bought new hoses hoping thats the issue, once i replace those and the issue persists ill reinstall the entire thing.
Old Today, 07:07 PM   #44361
DASVDUB
DASVDUB's Avatar
If you re install. Ensure you remove the oil thatís under said PCV before re installing
#assman, #saveboostedvw11, "yeah" -marshawn lynch, brunkelgotback, circlejerk thread, dat forum doe, dont care it got driven, dont quote pics people, dsgsr4women, dubpl8 1-900-suk-ndik, dubpl8 ate his dads ass, dubpl8 likes shrimping, fukyours2k, i pooped today, i'm an excellent driver, ihadsexwithmygastank, my body is ready, no one cares tiggy, nobodycares u washedit, purple helmet warrior, really nbdy crs u wshd it, sexybrunkel, srs ndy crs u washed it, vandorin was here, who's dubpl8?
