Old 05-24-2016, 10:41 PM   #15
sticksabuser
sticksabuser's Avatar
My question about this is whether PCV valve maintenance would still be recommended after installing this.
Old 05-25-2016, 03:20 AM   #16
jshay
jshay's Avatar
Drives: GLI
Originally Posted by jackhossross View Post
I was thinking the mention of other brands or pricing could be against the rules!???!
Idk - I'm not very forum savvy.
You posted on the Golf R section. This is the GTI section
FrankenTurbo GLI Build Thread
Old 05-25-2016, 03:37 AM   #17
FriggenT
Ah ok that's a legit question. I'm sure Arin can answer better than I can. It's a different design, apr retains the oem pcv where others replace the valve cover.
That's because the OEM pcv valve is a weak link...or in other words, it sucks.
Old 05-25-2016, 04:12 AM   #18
Turbo Beetle
Drives: 2012 Turbo Beetle
The APR diagram shows a line from the catch can to the intake tube just before the turbo but does not show how the OEM tube it replaces at that connection is plugged, or rerouted. So what do you do with the OEM tube that connects to the intake tube just before the turbo inlet.
Turbo Beetle is offline   Reply With Quote
Old 05-25-2016, 05:07 AM   #19
tofuD01
Drives: VW Golf Mk6 Gti
Originally Posted by TesseracT View Post
Hi Arin,
With this kit, what happens with the OEM PCV Breather Hose (06J103213D) ? There's no mention of it at all on the APR website.
From what the OP states, the OEM PCV Hose needs to be blocked off with their boost tap to use the catch can.
2010 GTi DSG || APR ECU Stage 2 v2.4 | TCU v1.6 || APR Downpipe || Pipercross Intake || Soundaktor Delete || VWR Springs w/ TT struts || 034Motorsport Dogbone Mount Insert || GFB DV+ w/ main spring || GY Eagle F1 A3 (fronts) || 'R8' Coilpacks + BKR7EIX (0.025") || Vibrant bottle resonator / stock catback || New engine at 63.5k miles..
tofuD01 is offline   Reply With Quote
Old 05-25-2016, 06:26 AM   #20
mfractal
Drives: A3 8P Sportback 2.0T
Not really. The op states that you block off the intake manifold connector with a boost tap. But what about the house that comes out the pcv and goes to the intake?
Sent from my XT1572 using Tapatalk
Audi A3 Sportback 2010 2.0T DSG
CTS K04 @ GIAC HO + Intake + Boost pipes, APR DP + IC, Milltek Res Catback, Whiteline WALK & PU bushings, KW Street Comfort
mfractal is offline   Reply With Quote
Old 05-25-2016, 09:12 AM   #21
GoodTimesIndeed
GoodTimesIndeed's Avatar
Drives: 2011 GTI 2Dr DSG
From what I can guess it will go like this:
Front port from OEM PCV out to catch can, the rear port would have to be blocked so that when in boost it forces catch out through front port as well.
From the catch can it will exit and connect to the air intake port (where the rear PCV used to connect to).
Old 05-25-2016, 09:25 AM   #22
bart2278
bart2278's Avatar
It was not inappropriate, I was more or less requesting why it was deemed inappropriate.
Regardless, it looks like it simply didn't go through - appreciate your reply.
I asked what makes this catch can different than other catch cans already on the market for the MKVI and why the price was on the higher end - also that I am new to the platform.
Thanks for helping!
What makes it different? Nothing. It is another expensive catch can.
Why is price on the higher end? Because APR
Eurodyne Tune • ECS Intake • RSR Clutch • Peloquin LSD • Fluidampr Crank Pulley• Neuspeed FMIC • Charge & Top Pipe • Turbosmart Thing • Dieselgeek Short Throw • Eurojet Catless DP • Vanguard Catback • R8 Coils • Bosch Plugs • 034 Street Density Trans/Motor Mounts • Advanti HY Hybris Black • Conti ExtremeContact • Mabotech m380h w/tune
Old 05-25-2016, 09:59 AM   #23
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
Hi Arin,
The rear hose is removed, and the port is blocked with the included block off plug. It's the silver and orange piece in the photo above.
Originally Posted by mr wrong View Post
I'm surprised they're peddling the 'reduced carbon buildup' narrative that was debunked ages ago...???....
The system can help to reduce carbon buildup and other junk from entering the engine, pooling in intercooler hoses, coating the intercooler, valves, manifold and so on. It will not 100% eliminate carbon buildup.
For PCV valve maintenance, what did you have in mind?
The "weak link" occurs when the factory PCV systems see boost pressure. The factory PCV has a check valve designed to prevent the system from seeing boost pressure, but the check valve can fail.
Our system eliminates the “weak link.” The system never sees boost pressure.
Normally, the way it’s setup from the factory, a hose runs from the manifold to the PCV valve. Under naturally aspirated mode (idle), vacuum sucks on the PCV valve and opens the check valve. When you get on the throttle and boost the engine, flow goes the other way. Now boost pressure acts directly on the PCV, and the check valve has to close to prevent boost from going through the system.
As mentioned, our system eliminates this completely. The front manifold port is blocked off. Gasses are now routed into the can. In doing so, we can retain the factory PCV, which as a cyclonic separator designed to help separate out good oil from the vapors, which fall back into the engine, rather than dumping into the manifold, or intake system, or from being trapped in the can.
So, our system never sees boost, which is what cause it to fail. The system goes like this:
PCV -> Catch Can -> Intake (Pre turbo, so no boost)
The hose is removed, and the hole is plugged with the included tap. It's the silver and orange piece in the kit.
That statement is about the manifold port. If you have our boost tap, simply install the supplied NPT tap, and the boost tap blocks off the front PCV port.
Old 05-25-2016, 10:16 AM   #24
estepnie
estepnie's Avatar
Drives: 2012 GTI CSG
In to see if there is enough clearance with unitronics dv relocation kit.
GIAC X2|Unitronic Intake|Neuspeed TOB, TBP & FMIC|Unitronic DV Relocation Kit|GFB DV+|R8 Coil Packs|SPM Custom TBE|VWR Springs|Bilstein B8 Dampers|Hotchkis F&R Sway Bars|034 Motorsports Endlinks|SuperPro ALK|Unibrace UB XB RB|TyrolSport Subframe Collars F&R|034 Motorsports Engine Mounts|Spulen Dogbone Insert|OEM LED Tails|Smoked Side Markers|Rear Wiper Delete|Neuspeed RSe52s|P3 Boost Gauge|Full Interior LED
Empire State Euros
estepnie is offline   Reply With Quote
Old 05-25-2016, 10:25 AM   #25
FriggenT
Oh Arin just say it...it sucks, most will go out around 40k anyway from what humble mechanic said.
Old 05-25-2016, 11:08 AM   #26
Arin@APR
Arin@APR's Avatar
As I mentioned earlier, the factory system is designed to see, and stop, boost pressure through the use of internal check valves. This pressure can tear the check valves, or cause the system to fail in other ways. Since we're removing boost from the system, the valve doesn't have the same opportunities to fail and thus can still be used to separate oil.
Old 05-25-2016, 11:39 AM   #27
steve9842015
Drives: 2011 4 dr GTI /DSG
I've been looking into this for a bit. I know this must be talked about a ton, but what are the common symptoms of the PCV failing? I'm just about to hit 70k; been APR k04 for maybe the last 5k.
I was looking at the ECS one, but heard issues of the hoses not being a proper fit. The way this one mounts seems to be better as well.
2011 United Grey 4dr GTI | APR k04 v3.1 | GodSpeed v2 IC | IE Intake | Billy Boat TBE | ST X Coils | Depot Golf R LED Tails | GFB DV+ | AWE S3 TOP + Neuspeed TPB | Neuspeed RSE12's + PSS | NSP Boost Gauge | 034 Street Density
steve9842015 is offline   Reply With Quote
Old 05-25-2016, 12:04 PM   #28
Arin@APR
Arin@APR's Avatar
The main most obvious one will be a boost leak, and underboost code.
