Old 05-25-2016, 12:11 PM   #29
Speeddemon69
Drives: 2012 MK6 GTI
Will this work with aftermarket intakes like IE?
Old 05-25-2016, 12:30 PM   #30
FriggenT
As I mentioned earlier, the factory system is designed to see, and stop, boost pressure through the use of internal check valves. This pressure can tear the check valves, or cause the system to fail in other ways. Since we're removing boost from the system, the valve doesn't have the same opportunities to fail and thus can still be used to separate oil.
Ok, I wasn't insinuating your part was bad btw, just that the plastic junk they use with many parts on this car suck...the pcv is one. The check valve either gets broken, carbon built up, or the top diaphram fails, but yes, removing anything boost from it will likely extend it'slife greatly.
Old 05-25-2016, 12:56 PM   #31
Speeddemon69
Hyde16 review this one!!
Old 05-25-2016, 01:38 PM   #32
FriggenT
Originally Posted by steve9842015 View Post
I've been looking into this for a bit. I know this must be talked about a ton, but what are the common symptoms of the PCV failing? I'm just about to hit 70k; been APR k04 for maybe the last 5k.
I was looking at the ECS one, but heard issues of the hoses not being a proper fit. The way this one mounts seems to be better as well.
You can do the dipstick test, pull it out while the car is running and if the idle doesn't change. That may not mean that it's not bad however. You can also see a small hole on the top section of the pcv off to the side, cover that hole and see if idle does anything different, that can be the source of a pretty big leak since the rubber diaphram is in the top section. Also, excessive oil can be ano there section.
Old 05-25-2016, 01:46 PM   #33
cons
cons's Avatar
Drives: Tiguan APR K04 + DQ500
Arin, does it fit to Tiguan EA888 gen.2 engine?
cons is offline   Reply With Quote
Old 05-25-2016, 03:00 PM   #34
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
If the intake works with the factory PCV system, I don't see why not as we're using OEM Norma connectors.
To the engine, yes, but the mounting bracket and hose length was designed for the GTI and one for the GLI. The Tiguan has a similar mounting point, but I have not tried it, and it's only a single screw mount vs dual.
Old 05-25-2016, 05:11 PM   #35
Speeddemon69
What about hose length to aftermarket intake?
Old 05-25-2016, 05:36 PM   #36
Arin@APR
Arin@APR's Avatar
Same answer, unless it was moved dramatically.
Old 05-25-2016, 05:40 PM   #37
Speeddemon69
So there is a little slack to the lines then? Enough to accommodate a few inches off?
Old 05-25-2016, 10:34 PM   #38
Speeddemon69
Hey Arin do you have a close up pic of what's included besides the catch can? Can't really tell, at least not on my phone lol
Old 05-25-2016, 11:06 PM   #39
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
I'm down, it would be the perfect time to compare to the newly installed ECS Catch Can which I listed my concerns on their layout and setup in their product launch thread.
Anyone else want to see a review on this?
Arin?
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 05-25-2016, 11:11 PM   #40
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
APR Oil Catch Can for the MK6 Golf / GTI and Jetta / GLI!
For the record, there a several major differences between the ECS one I see right off the bat, this would make an interesting run down and review on unboxing, installation and direct comparison to the ECS, 034 and Forge one I've run in the past. Most importantly the major advantages of the APR CC vs. the ECS CC.
YouTube: HYDE16
Old 05-25-2016, 11:26 PM   #41
Speeddemon69
APR Presents the MK6 Oil Catch Can System
This is like the ECS CC on steroids! I'm getting one unless it does not fit the IE intake for any reason. Hyde16 reviews FTW!
You got my vote for a review!
Old 05-25-2016, 11:41 PM   #42
kthor703
kthor703's Avatar
Arin?
I would
