Old 05-26-2016, 04:17 PM   #57
Speeddemon69
Drives: 2012 MK6 GTI
Damn u right Tapatalk messing shit up like always. Sorry lol
Old 05-26-2016, 04:39 PM   #58
dkg010
Drives: 2013 GLI
Originally Posted by bart2278 View Post
wut?
engine can be designed that doesn't get carbon buildup and require cleaning no?
or let all that other junk get into the engine?
dkg010 is offline   Reply With Quote
Old 05-26-2016, 09:10 PM   #59
Speeddemon69
Wut? x 2
Old 05-26-2016, 09:14 PM   #60
Speeddemon69
The silver / orange thing is the thread plug for the rear PCV pass through port, that's no longer used.
Is that a self tap bolt? Or the Pcv hose has threading? Should I use thread sealant?
Old 05-26-2016, 09:58 PM   #61
Blaznjoe
Blaznjoe's Avatar
Drives: 2012 MK6 GTI 2-D CSG
What is the volume (fill capacity) of the can itself?
I notice (and your website states) it uses the OEM style quick connectors (plastic) on the line "ends", are the lines plastic as well? (similar to the OEM line off the intake manifold>engine.) Or oil resistant rubber with insulation?
2012 MK6 GTI 2-D CSG 6SP-MT
GIAC Stage 2e40|SPM Street DP|SACHS Performance Coilovers|VOLK ZE40's|Neuspeed BBK,Pulley,P-Flo,TOP,FMIC,CBE,SS brakelines,& ShortShifter|Whiteline ALK|Hotchkis F & R Swaybars|Autotech Rotors|Hawk Pads|EuroSport X-Brace|TyrolSport DS SF C Kits|GFB DV+|SB.S2.SMFW|Wavetrac|Michelin PSS|Podi|ECS CatchCan www.kopropo.com/america/
Blaznjoe is offline   Reply With Quote
Old 05-27-2016, 10:09 AM   #62
jamlee
Drives: 2013 cw gti, 2013 gsxr1000
the orange on the silver blot looks like loctite and its supposed to go into the boost tap to block off the port where the oe hose goes from the manifold to pcv
jamlee is offline   Reply With Quote
Old 05-27-2016, 10:12 AM   #63
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
You just screw it in and go. No extra work on your end.
Old 05-27-2016, 10:19 AM   #64
Arin@APR
Arin@APR's Avatar
You'll want to drain the can if it gets half way filled. The quick drain on the bottom will make that easy. You can either put a cup under it, move the knob, and drain, or use the elongated quick connect drain hose.
The lines are buna N, for use with oil / fuel / coolant etc. Basically, the lines are designed for all the junk that will flow through them.
Old 05-27-2016, 10:51 AM   #65
bart2278
bart2278's Avatar
I'm not %100 but I think all direct injection engines suffer from carbon buildup my man
Eurodyne Tune • ECS Intake • RSR Clutch • Peloquin LSD • Fluidampr Crank Pulley• Neuspeed FMIC • Charge & Top Pipe • Turbosmart Thing • Dieselgeek Short Throw • Eurojet Catless DP • Vanguard Catback • R8 Coils • Bosch Plugs • 034 Street Density Trans/Motor Mounts • Advanti HY Hybris Black • Conti ExtremeContact • Mabotech m380h w/tune
Old 05-27-2016, 11:05 AM   #66
cons
cons's Avatar
Drives: Tiguan APR K04 + DQ500
Arin, Why do you connect intake of your catch can to idle breathe port (on the front valve cover) and block boost port of PCV? Will the PCV work on the idle only or on the boost too? I didn't see such solution before.
cons is offline   Reply With Quote
Old 05-27-2016, 12:18 PM   #67
Speeddemon69
Nope lucky Europeans have a 5th injector for flex fuel I think (not really sure why they have it) that helps with that and I'm sure other DI engines have something similar. Wish we had that here for more power and carbon prevention.
Old 05-27-2016, 12:36 PM   #68
Arin@APR
Arin@APR's Avatar
Boost. The front and rear tubes are linked, but operate with check valves in place to ensure they can't see boost pressure when stock.
Old 05-27-2016, 12:37 PM   #69
Arin@APR
Arin@APR's Avatar
They don't. The B8.5 A4 engine has a 5th injector on some cars. It's only for ethanol cold starts at something like 10c and below. It otherwise never sprays at all.
Old 05-27-2016, 12:37 PM   #70
bart2278
bart2278's Avatar
I learn something new everyday, and today it didn't cost me any money. thanks
