Old 03-20-2017, 05:10 PM   #15
TimS
Drives: '12 Golf R
No, FSDs automatically adjust dampening, there's not a knob on the outside.
I like it a lot - it's just the right height, and the ride is firm but not harsh. Kinda like a Mk7 R in sport mode.
Here's the vortex thread about them.
Old 03-20-2017, 06:03 PM   #16
MmmmmBoost
Drives: 2013 GTI MK6
Thanks man, seems that theres only one guy on there thats tried em. So many options to choose from
MmmmmBoost is offline   Reply With Quote
Old 03-21-2017, 01:57 AM   #17
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
PM this guy:
http://www.golfmk6.com/forums/member.php?u=42690
I just put Koni FSD's on his car for him, paired with VWR springs
2017 Passat VR6
Old 03-01-2018, 01:31 PM   #18
damagi123
damagi123's Avatar
Drives: 2012 GTI DSG
Originally Posted by snobrdrdan View Post
PM this guy:
sorry for Necroposting but Did you get any feedback on how he liked that setup?
it would be awesome if lowering with comfort dampers like that could give you nice mix of comfort and control but it seems like it might be mismatched??
APR K04 V3.1, APR DSG tune, APR Intake, Uni intercooler, UR Catless Downpipe, CTS Chargepipe & TOP, W.A.L.K, APR 27mm Front and Rear Sways, ECS Dogbone insert, 034 Subframe Collars, Pedalbox throttle controller, 17" Fujins on Conti DW
Old 03-02-2018, 02:58 AM   #19
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
I never followed up, but he's logged on recently...just send him a PM
Or pair them with the Koni STr.T's (which are softer) or the Koni Sports (which can be soft and then adjusted firmer from there)
2017 Passat VR6
Old 03-02-2018, 10:46 AM   #20
TimS
Drives: '12 Golf R
I guess I should post an update now that this is back from the dead and I've had the setup for 2 years and 45k miles.
I have regrets. Ride quality sucks now - FSDs are designed for OE springs and that's it. Get Koni Yellows or Bilstein Sports.
Old 03-02-2018, 10:46 AM   #21
Short Bus
Drives: '10 GTI
If you want to get the most out of FSDs you probably want to stick with stock springs. Due to how they function you might not trip the "soft" valving unless there's enough bump travel. If you're not running bumpstops shortened by the amount the springs lower the car the valving may always use the firm valving. Then if you do run shorter stops they will have to be far more firm, so big bumps that use the soft valving will lead to a crashy, harsh ride because the stops ramp up the rate far more quickly than the stock stops.
If you want to go a bit lower and still want a smooth ride your best bet is probably a set of Neuspeed Bilstein Sports, and if that's still not soft enough you'll have to find a tuner that can revalve them to suit your needs.
Thankfully Bilsteins are more or less designed and supported with this kind of customization in mind.
Old 03-03-2018, 03:21 AM   #22
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Oh yeah...definitely this
2017 Passat VR6
Old 03-03-2018, 08:55 AM   #23
riceburner
Drives: 2012 GTI DSG / K04
This kit is actually a pretty kicking deal. The trivalve shocks usually go for 549 and springs for 279...
