This is likely due to the bypass of the component protection. These units from factory have component protection, where after a certain amount of time it locks the radio. In order to by pass it, they do some sort of reset to bring the counter back to 0.
Thanks for helping.
I am not sure about this. I am now connecting the phone on bluetooth but not using either android auto or mirrorlink (because I gave up on them).
For some reasons now the bluetooth doesn't ask me to allow access etc, it just connects normally as it did with the stock bluetooth unit. I think if it was a lock bypass it would present itself in any situation
If you bring the equalizers all down to the very bottom and treat that as your new baseline it will help in the assistant voice. The quality should be the same as you would just increase the volume of the unit to hear your music now. What speaker system do ya have?
The problem with eq(s) is that putting everything up or down is not like being on "flat" at higher or lower volume. I have the hobby of sound engineering and trust me that every different setting from flat on either a parametric or graphic eq will affect the sound, as it acts on specific frequency bands.
I use a Focal kit for the MK6 with an Audison processor/amplifier (bit 4 prima)
With nornal use also this is ok
I forgot to mention: it actually reads FLAC files which is amazing! I just tried for fun and they work!!
The reason I am reporting the bugs above on my previous post is because I would like to help a developer to get them sorted. Luckily the unit works fine without AA or Mirrorlink, better than the RCD510, so it is ok. But it is sad that other features just don't work
For the sound I am quite certain as the Audison is flatting out the entire signal from the stock stereo and then I apply sound processing on the Audison like crossovers, eq on each speaker, delays..
