Old 03-06-2018, 11:40 AM   #1359
dadjoke
Drives: '14 Tiguan R-Line
Originally Posted by zsm722 View Post
This update worked for me as well! I have the same unit described by Simba92.
It looks like the wetransfer link is dead now, but I have uploaded it myself, hopefully it stays up. Follow the instructions above.
http://www.mediafire.com/file/zrc3d1..._VW_PQ_GP1.tar
Just wanted to bump this link because I was able to use it to update the firmware on my no-name unit. I also ran into the “Variant Conflict Error”, so I used the 5515 update from the link below and then downgraded to 5314.
https://youtu.be/ge_5Rpp1kg8
I also thought that it'd be helpful to list out the pros and cons since updating my firmware. The cons aren't dealbreakers IMHO.
Pros:
  • Swapped out Baidu CarLife for Android Auto
  • Red accents instead of yellow accents
  • The post-Siri/phone call volume jump seems to be addressed, but I also adjusted the max volume and voice command (I think that's what it's called) levels under Settings > Sound
Cons:
  • No more EQ options to choose from
  • Inconsistent accent color in the Settings menu — some are yellow/orange and some are green
dadjoke is offline   Reply With Quote
Old 03-07-2018, 12:47 AM   #1360
Atsiki
Drives: Golf
Look here for firmware update
http://rcd330plus.com/showthread.php?tid=6
For 187A desay theme and video play
Look here :
https://youtu.be/opS__OmWQGc
Atsiki is offline   Reply With Quote
Old 03-08-2018, 03:34 PM   #1361
eurosport
Drives: '14 Golf
Originally Posted by HetfieldInc View Post
Damn. It looks like the one I ordered “desay” manufacturer doesn’t have any firmware upgrades so I can’t add android auto, which isn’t a big deal since I use iPhone.
The only thing that I would have done is upgrade to the red theme so that all the screens better match the interior. I saw the red theme on rcd330plus.com
Anyone know why there isn’t any firmware for the desay model?
I have the same unit. I believe the reason there are no firmware updates to the Desay model is because it runs on WindowsCE, whereas the other no-name models run Linux.
My Desay unit definitely has its issues. Periodic reboots in cold weather. "Baidu Car Life" option when phone is plugged in (useless). Bluetooth recognizes the phone quickly, but playing music can take a while. My CarPlay disconnects from the phone periodically (I still need to try a different cable).
eurosport is offline   Reply With Quote
Old 03-09-2018, 07:03 PM   #1362
Atsiki
Drives: Golf
This is problem of desay 187A cold time restarting self 5-6 times and after work well
Old 03-09-2018, 11:37 PM   #1363
HetfieldInc
Drives: Black 2013 Drivers Edition
Does the Desay version 187b have any issues?
APR Stage 2 v2.4 // APR tcu tune // APR Cast downpipe // Neuspeed non resonated SS catback // APR Carbonio Intake // R8 Coilpacks // Spulen dogbone insert // Smoked side markers // OEM Cherry Red Euro Tail Lights
HetfieldInc is offline   Reply With Quote
Old 03-10-2018, 04:20 PM   #1364
The Red Warrior
Drives: Mk5 GTI
The only'isue' I have with mine is that the audio mutes itself sometimes if the radio has been off for only a few minutes. For instance when you gas up. You come back to the car, turn it on but there is no sound. You have to switch to another source (at which point the audio comes back) and then switch back to the source you were listening to if that's what you want.
I've never heard of anyone else with this issue though.
The Red Warrior is offline   Reply With Quote
Old 03-11-2018, 06:57 AM   #1365
spicypiel
Drives: Golf Mk5 GT TDI 170ps
Guess there's no news on any fixes coming for the noname firmare then?
No surprise, sort of expected this but doesn't detract from the slightly annoying experience when using the unit.
spicypiel is offline   Reply With Quote
Old 03-11-2018, 03:46 PM   #1366
MJGTI
Drives: 2012 4DR CSG GTI
New RCD330 Plus Headunit with Mirrorlink/Carplay
I read about the first 500 posts and was ready to pull the trigger but I guess a lot a changed in a few months, so apparently I have some catching up to do on models, sellers, and firmware.
Edit. It looks like this is the one from AliExpress, right?
https://m.aliexpress.com/item/32815705967.html
Aside from, who can give me the cliff notes, my question is, so any of these keep satellite functionality or will I need to use the Sirius app through carplay?
MJGTI is offline   Reply With Quote
Old 03-11-2018, 04:52 PM   #1367
Mr_Dog
Drives: 2012 GLI
Pros:
Cons:
The inconsistent accent colour is deliberate :P
I sat in a 2016 Jetta with the OE NA unit. And it has the colours too. I.e Green is for phone, orange for settings etc
Old 03-11-2018, 07:34 PM   #1368
chelseafan95
Drives: Mk6
Originally Posted by bobbybasic View Post
Sounds like it is currently functioning as a mute button? Mine was set-up like that and I had to use VCDS to switch it over to Siri.
What coding did you have to do I VCDS? Mine is also currently functioning as a mute button, but I would much more prefer it to activate Siri.
chelseafan95 is offline   Reply With Quote
Old 03-14-2018, 09:20 AM   #1369
Atsiki
Drives: Golf
this firmware Carplay-Carlife-Mirrorlink with red menu :
http://rcd330plus.com/update/std_531...arlife_Red.tar
And
This firmware Android Auto - Carlife -Carplay with Red - ( no Mirrorlink )
Warning.. no body try it yet .. i am not responsable if you guys want try.
Old 03-20-2018, 02:24 PM   #1370
1616sixx
Drives: 2009 Mk6 2.0 GT TDI
Hi all
I’m having issues with my camera... 187B Desay model.
Camera has worked perfectly since fitting until the last couple of weeks and I can’t work out if it’s the head unit, camera or delay timer at fault.
My camera image now looks like this:
https://youtu.be/Jcf7aBKr4lI
Black and white image and flashes STOP, it’s also flipped the image so left & right are wrong.
The track lines have also changed completely.
Sometimes the camera will also switch off and say camera not currently available.
Hoping it’s just the camera at fault but wondered if anyone has seen this before?!
1616sixx is offline   Reply With Quote
Old 03-23-2018, 06:32 PM   #1371
HetfieldInc
Got my rcd in today and went to install it annnnd.... they shipped me a damaged one. There’s a huge gouge and scratches all above the radio button. I’m trying to do a return though eBay but so far haven’t heard from the seller. Kind of put a damper on this whole project. I’ve heard these shippers in China can be a pain in the ass and try to make me pay for return shipping which is almost more than the unit itself.
Any suggestions? I’ve only bought a couple of things on eBay before and never had anything damaged
Old 03-23-2018, 08:33 PM   #1372
kerp
kerp's Avatar
Drives: 2012 GTI CW
Just file a claim through eBay or PayPal, if the seller isn't reasonable.
kerp is offline   Reply With Quote
