Old 03-03-2018, 01:55 AM   #1
nevekd128
nevekd128's Avatar
Drives: sf muni
f23t misfires
My f23t gets misfires only at 6k rpm and gives a sensation that it hits a rev limiter. It only happens in 3rd or 4th gear.
Im running a TT tuning catted down pipe (2.5in 400 cell). I considered trying a 3in catless downpipe, but im not sure if that would cure the issue
I recently replaced my hpfp about 500 miles ago
New plugs gapped to .026
Fresh 93 gas
R8 coil packs
MY12 gti with a f23t frankenthingy and man pedal transmission. Car rides sorta low for scene points
nevekd128 is offline   Reply With Quote
Old 03-03-2018, 02:26 AM   #2
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Probably need a smaller plug gap. 0.26 may be too wide for the hp
Old 03-03-2018, 08:25 AM   #3
GroceryGTIer
Drives: 2013 black Wolfsburg
Got the same misfires at 5500-6k
Old 03-04-2018, 06:19 AM   #4
SkyNet
Drives: Leon TSI
What’s your tune?
SkyNet is offline   Reply With Quote
Old 03-04-2018, 10:05 AM   #5
thatspsychotic
thatspsychotic's Avatar
Fresh 93 gas
R8 coil packs
Do you have a way to take logs? The easy answers are reduce gap to 0.024", clean your MAF (can help occasional misfires but yours sounds more than occasional).
If that doesn't do it, it could be exhaust valve float. Read through this thread for more info. Going to a catless downpipe would reduce exhaust back pressure so it may actually help against valve float. But if you check the markings on your valve springs like in that thread, it may only help for a little while, since it isn't solving the actual valve spring problem.
Present: APR Stage 1+ v2.4 | APR Carbonio | R8 Coils | GFB DV+ | Unibrace UB | Tyrolsport Deadset | SuperPro Offset LCA Bushings | Enkei Raijin Gunmetal 18x8 et45 | Michelin PSS 245/35R18
Future: APR Downpipe | BFI Mounts | PTP Turbo Blanket | ST Coilovers
Old 03-04-2018, 10:53 AM   #6
GroceryGTIer
Originally Posted by SkyNet View Post
What’s your tune?
I'm on United motorsports, but I'm suspecting an issue with the o2 sensor or maybe fuel pump since my mileage didn't improve after getting doing my carbon cleaning, and have a previous rich code. Who know though man? These are the only cars where you have to replace everything before they are reliable.
Old 03-04-2018, 01:25 PM   #7
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Seeing as f23 goes above k04 levels, I would bet plug gap is too wide at 26
Old 03-04-2018, 03:07 PM   #8
GroceryGTIer
I was at .026 on f23 before, it did fine. Idk if OP said which plugs he used, but I used the NGK PFR7S8EG.
Old 03-04-2018, 03:21 PM   #9
brobst
brobst's Avatar
Drives: CSG mk6 6MT
Above you said you have misfires. So do you have misfires or not? I would not consider it good. Is it driveable sure, but not ideal.
Old 03-04-2018, 03:42 PM   #10
GroceryGTIer
I am not running that plug right now... I said when I had my f23 that's what I ran, and, at that gap.
My next step will be to try that plug again since typical NGK may not be getting it done.
Old 03-04-2018, 04:20 PM   #11
nevekd128
nevekd128's Avatar
Drives: sf muni
I’m on a stratified tune and going through revisions. I will try opening up that gap a little bit and try a different exhaust. My hpfp is a new one unit as of 500 miles ago. And I’ve cleaned my primary 02 sensor and maf recently too
