Old 03-03-2018, 05:41 PM   #1
bbqchipsfan
Drives: 2011 GTI (Manual, 4-door, CSG)
Upgraded shocks/struts with H&R springs
Hi guys,
Wanted to get your advice on which route I should take to fix my suspension. I installed H&R lowering springs on my car about ~6 months ago. It's my first lowered car so I wanted to go with a moderate drop which is why I chose lowering springs over coilovers. The ride quality wasn't affected immediately, but over time it has become really bouncy, intolerable, and sometimes dangerous so I think it's time to upgrade my shocks/struts or switch to coilovers.
Questions:
1) If I'm content with my current drop, would simply upgrading my shocks/struts solve my problem of a bouncy ride, or would I need to switch to coilovers? Both performance and comfort are important to me, but if i had to pick one, it would be comfort.
2) If I go shocks/struts route, it sseems like Bilstein and Konis are the brands most recommend. I have done extensive research into both and I think I want to go with Koni STR.T's. For what I'm trying to do, would these be appropriate or do you recommend the Bilstein B8s or Koni Yellows/FSD?
Thanks for your help in advance!
bbqchipsfan is offline   Reply With Quote
Old 03-03-2018, 05:55 PM   #2
Tyler12108
Tyler12108's Avatar
those shocks will fix the bounce but might be a bit stiff if you're concerned about comfort
Tyler12108 is offline   Reply With Quote
Old 03-03-2018, 06:20 PM   #3
bbqchipsfan
Just updated my post after finding more threads on this forum on Koni STR.T/Yellow/FSD. I believe your comment was if I went Yellow - do you think STR.T would be better for comfort?
I plan on installing it & leaving it, so adjustability isn't a deal breaker. I also have never tracked the car (nor do I plan on doing it lol).
Let me know.
Old 03-03-2018, 10:43 PM   #4
moarlo
Drives: 2017 gli
Im 100% happy with the str.t’s on my golf r, running in conjunction with h&r super sports
moarlo is offline   Reply With Quote
Old 03-05-2018, 02:41 AM   #5
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
STr.T's are close to the equivalent of Koni Sports on the full soft setting
If you don't want them stiffer, or the flexibility/adjustability of going stiffer, then get the STr.T's. They're also cheaper too:
https://www.tunersports.com/koni-str...-2_p16098.html
2017 Passat VR6
Old 03-08-2018, 12:09 PM   #6
zef
I enjoy my Koni Yellows but agree they're on the firm side. STR.T are a great option. Just get a good set of shocks and you'll be fine. H&R are a bit much for the stock shocks to handle
Old 03-08-2018, 08:11 PM   #7
sniper27
sniper27's Avatar
Drives: 2013 GTI DE
I have SRT.T with DG springs. While they do feel really good initially, I find that they wear out pretty quickly and becomes bouncy and too soft. It actually bottoms out if I hit a bump or did hard enough. It comes with a lifetime warranty, but it's a hassle to remove it and ship it back and reinstalling a new set every couple years. I plan of dumping mine soon and just go with Koni yellows. This is of course my preference. Some people may be satisfied with the STR.T.
sniper27 is offline   Reply With Quote
