Old 03-06-2018, 10:21 AM   #1
reds4biturbo
Drives: 2010 VW GTI GIAC Stage 2
DSG Leaking Oil
Hello, I had noticed some oil in my driveway and just figure it was the drain plug for the engine oil but after getting under the car it looks to me like it's coming from the dsg trans. Here's a pic below. Any insight would be much appreciated.
reds4biturbo is offline   Reply With Quote
Old 03-06-2018, 10:24 AM   #2
smanierre
I'm not sure if it's the same for dsg as manual but it could be a blown out rear main seal
Build Thread
Old 03-06-2018, 10:33 AM   #3
lilonespaz
lilonespaz's Avatar
can you re upload pic?
Old 03-06-2018, 10:58 AM   #4
Ik1015
Drives: mk5 ug
I bet rear main seal failed.
Ik1015 is offline   Reply With Quote
Old 03-06-2018, 11:18 AM   #5
reds4biturbo
Here's the picture. Thanks guys.
Old 03-06-2018, 04:13 PM   #6
FocalPoint
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
there's no picture. Go to imgur, upload it and then link us here.
Old 03-06-2018, 07:40 PM   #7
reds4biturbo
Sorry about that!
Old 03-06-2018, 10:40 PM   #8
BudgetPhoenix
Drives: 09 GLI
Rear main seal
Old 03-06-2018, 10:49 PM   #9
reds4biturbo
Originally Posted by BudgetPhoenix View Post
Rear main seal
Of the DSG trans?
Old 03-07-2018, 01:00 AM   #10
BudgetPhoenix
Drives: 09 GLI
Of the DSG trans?
The rear main seal is between the engine and trans where the crankshaft is on the engine side so when it goes you will see oil leak down to where the trans and engine mate. Pretty common on 2.0TSI unfortunately. Poor PCV system and failures of it can cause overpressurization of the crankcase causing rear main seal to blow out. Rear main can also cause engine to run rough and throw codes too
Old 03-07-2018, 09:29 AM   #11
Ik1015
Drives: mk5 ug
^x2. Yes, rear main seal. You can see oil spreads around tranny mount and subframe area. Clean up area with brake cleaner and you can see seepage or leaking again. Check oil level and refill until replacing RMS. Mine just replaced several weeks ago. First replacement failed and leaked again and dealer did again. Now, no leaking at all. Repair cost varies between $800~$1,200??? I did at dealer because about $150 differed from Indy shop and dealer gave me loaner car and near by. GL!
Old 03-07-2018, 09:35 AM   #12
reds4biturbo
Thanks for the replies guys! I will clean it up with some brake cleaner and check the leak again as suggested. So just to be clear you are saying this is engine oil and not dsg fluid?
Old 03-07-2018, 09:47 AM   #13
Dans GTI
Drives: 2010 MK6
Yes, they are saying its engine oil. The rear main seal has the job of sealing the crankshaft. When the RMS fails it at time seems that the transmission is leaking because the RMS is in between the engine and transmission. Replacing the RMS is not an easy or cheap task as it requires dropping the transmission. Typically a RMS failure is linked to a failed or about to fail PCV valve. So if your going to replace your RMS you should also change your PCV valve as they are also known to fail. It would be horrible to pay $1000 to replace your RMS for it to only fail a few weeks later due to a bad PCV.
Old 03-07-2018, 10:42 AM   #14
Ik1015
Drives: mk5 ug
Do not take PCV valve replacement from shop and that costs way higher than actual job(less than 30 miniutes job and only need torx (30?) bit and remove 2 coil pack).
Replace PCV by yourself and save $$. Buy revised OEM PCV valve.
