grambles423
Automotive Engineer
I used this link as a reference (PICS ARE HERE): http://www.golfmkv.com/forums/showthread.php?t=18676
I'm gonna use the pics from the DIY to keep users from having to jump across 2 forums. I believe this was done on an FSI, but the setup is very similar.
Tools Needed:
5/8" Spark Plug socket
Long Extension
Rachet
Zip Ties
New Spark Plugs (I used NGK Part Number: BKR7EIX. Dont use BKR7EIX-11 because they are not gapped for our vehicles!)
1) Remove Engine Cover
2) Unclip coil pack Harness
3) Pull Harness out of the way
4) Using zip ties, create your new Coil Pack Removal Tool and carefully remove coil packs. They're snug, but some wiggling around will unseat the rubber grommet.
5) Place your extension in the hole and make sure your socket is seated to the spark plug
6) Remove the Plugs (x4)
7) Install New Plugs (x4) Torque Spec: 30Nm
8) Re-install everything and inspect your work.
9) Beer
Tools Needed:
Long Extension
Rachet
Zip Ties
9) Beer
