Old 07-18-2012, 08:45 AM   #15
eduardot
eduardot's Avatar
Drives: '12 GTI
I just got mine from ebay for $65 shipped. The seller had it listed for $100 + $15 shipping. I sent him an offer saying a few recently sold for $50 and that is the most I would be willing to pay. It worked!.
Here are the other listings I was looking at:
3C8-907-336AJ same as 5HB-009-751-27:
http://www.ebay.com/itm/190636033430
http://www.ebay.com/itm/220934866417
3C8-907-336N same as 5HB-009-751-17:
http://www.ebay.com/itm/200781654289
http://www.ebay.com/itm/190698920037
Buy at your own risk. I'm not responsible if it doesn't work.
Edit:Placed an order at 1stVwParts.com for the sensors, housings, and wires. I just received a confirmation saying a few parts are out of stock, it will ship on Friday.
Last edited by eduardot; 07-18-2012 at 01:00 PM. Reason: adding info about 1stvwparts.com
eduardot is offline   Reply With Quote
Old 07-19-2012, 01:00 AM   #16
ThosKS
I edited the testing directions to add some interesting information I discovered today: the “64” and “LO” and the “80” and “HI” markings on the temperature scale are actually distinct settings. Compared with older Climatic systems (like the MKV) this is kind of a big deal.
When set to LO, the system disregards the temperature sensors and sets the hot/cold flap to 100% cold, regardless of actual interior temperature. Turn the knob up one click to 64, and auto temp regulation resumes.
When set to HI, the system disregards the temperature sensors and sets the hot/cold flap to 100% hot, regardless of actual interior temperature. Turn the knob down one click to 80, and auto temp regulation resumes. (This was interesting to observe today when it was 105 outside and the interior was still in the process of cooling down after work. Every time I clicked the knob back and forth between 80 and HI, the temperature of the air coming from the vents instantly went up or down by what must have been at least 50 degrees.)
This is going to be especially awesome for winter. The Climatic in my MKV didn’t have the extra “LO” and “HI” settings; it only had 64, 72, and 80. This may explain why the defroster in that car did such a crappy job of keeping the windshield clear in winter: I think the system started cutting back the heat when the interior reached 80 degrees, therefore not allowing the defroster to produce enough heat to keep the windshield clear in heavy snow when the temperature dropped into the teens. The addition of this “HI” setting on the MKVI Climatic should allow the defroster to run in full blown, unregulated forehead-melt mode and keep the wipers from packing up with snow and ice.
ThosKS is offline   Reply With Quote
Old 07-19-2012, 03:55 AM   #17
eduardot
eduardot's Avatar
Drives: '12 GTI
Can you post the wiring diagram you used to determine the pins on the 16-pin and 20-pin connectors?
I'm trying to learn as much as possible before my parts get here.
Old 07-19-2012, 10:51 AM   #18
Skirball
Drives: 2012 Golf TDI 6MT
+1 I was curious to see this as well.
Where did the wiring diagrams come from? I was searching around for a service manual but it seems nobody has made one for mk6? ...which seems odd in and of itself.
Skirball is offline   Reply With Quote
Old 07-19-2012, 11:09 AM   #19
eduardot
eduardot's Avatar
Drives: '12 GTI
I found this:
http://elsaweb.spaghetticoder.org/na...3/87/10060262/
It has a few diagrams, however, I don't understand the pin assignments.
For the 20-pin connector it only lists 11
For the 16-pin connector it only lists 12
I still believe the OP since he has it working. Furthermore, that elsaweb reference doesn't seem to be complete (or I don't know how to read it.)
Credit where it belongs:
Found the link to elsaweb from this post http://golfmk6.com/forums/showthread.php?t=40587
Old 07-19-2012, 12:34 PM   #20
ThosKS
I had bought a 24-hr pass to erWin to get the wiring diagram. I saved the info on my laptop at home and I can post the info after work tonight. I looked at that Elsaweb info and the pinouts seem to be almost totally different from what the erWin documentation had...weird.
Old 07-19-2012, 12:42 PM   #21
TurtleJames
TurtleJames's Avatar
Great write up. Thanks! I will try this with the older panel (3C8-907-336N) and let you know how it turns out. Couldn't find any newer ones in a price I was willing to pay.
2011 GTI Autobahn DSG | APR K04 | APR IC | Unitronic DSG Stage 2| Carbonio CAI | Neuspeed TOP | UR DP | Magnaflow CBE | P3 Boost Gauge |Unibrace UB / XB |OEM+ Interior / Exterior : Golf R LED Tails | RNS-510 | VW Rear View Camera | Dash Cubby | Under Seat Drawers | Euro Cup Holder | etc. | Q.T. McWhiskers Laser Defense System | VCDS and OEM RVC Services in Northern NJ |
TurtleJames is offline   Reply With Quote
Old 07-19-2012, 04:06 PM   #22
Smoky_Llama
Drives: 2012 CW 4DR GTI DSG w/SR & NAV
Very cool diy! While I don't really care for the semi auto system, how easy do you think it is to swap just the more metallic knobs from an older car to a newer one?
Smoky_Llama is offline   Reply With Quote
Old 07-19-2012, 11:32 PM   #23
ThosKS
(A) 5-pin Harness Connector, in Wiring Diagram T5
1 - 3rd Blower Speed
2 - 2nd Blower Speed
3 - 1st Blower Speed
4 - 4th Blower Speed
5 - Terminal X
(B) 16-pin Harness Connector, in Wiring Diagram T16e
1 - Temperature regulator door motor -V68- warm
2 - Evaporator temperature sensor -G308- or Evaporator vent temperature sensor -G263-
3 - Air distribution door motor position sensor -G645-
4 - Footwell outlet temperature sensor -G192-
5 - Temperature regulator door motor position sensor -G92-
7 - +5 V for Temperature regulator door motor position sensor -G92-
8 - Ground for the Front air distribution door motor position sensor
-G92-, the Footwell vent temperature sensor -G192-, the air distribution
door motor position sensor -G645-, and the evaporator
temperature sensor -G308- or evaporator vent temperature sensor -G263-
9 - Recirculation door motor -V113- open
10 - Recirculation door motor -V113- close
11 - Temperature regulator door motor -V68- cold
12 - Air distribution door motor -V428- open
13 - Air distribution door motor -V428- closed
(C) 20-pin Harness Connector, in Wiring Diagram T20c
3 - Dash Outlet Temperature Sensor -G191-
5 - High Pressure Sensor -G65-
7 - CAN Low
8 - CAN High
12 - Right seat heater (optional)
13 - Seat heating (option)
15 - Terminal 75 seat heater (optional)
16 - A/C Compressor Regulator Valve -N280-
18 – Dash outlet temperature sensor -G191- ground
19 - Terminal 30A
20 - Terminal 31
Old 07-20-2012, 05:13 PM   #24
eduardot
eduardot's Avatar
Drives: '12 GTI
Thanks for the wiring details. It is reassuring to see that information.
Update on my orders:
- 1stVwParts shipped the sensors, housings, and wires today
- Climatic controls should get here on Wednesday
Looking forward to having this installed by next weekend.
Old 07-21-2012, 08:43 AM   #25
JS12
I received my climate control from eBay but am still waiting on the parts from 1stVwParts.
The control unit I got also has some minor scratches on the glossy black plastic that I'd like to swap with my existing one. To remove, did you pry from an edge with a small flat object or is there some other method? I have some small screwdrivers that I could try but I'm hesitant since everything on the unit is plastic.
Thanks.
JS12 is offline   Reply With Quote
Old 07-21-2012, 01:47 PM   #26
Skirball
+1
Mine was actually in pretty good shape (much better shape than the 2010 Jetta it came out of). It has a bit of grime on the face plate but I think with a little Goo Gone I might not even need to swap it. Need to go grab some Goo Gone so I can debadge anyway...
Old 07-21-2012, 04:15 PM   #27
ThosKS
Thanks.
The faceplate is attached to the control panel with 8 molded-in clips (see photo below). I used a sewing needle to pry up the upper right corner and release the first clip. After that, I was able to release the remaining clips by gently squeezing and prying the edge of the faceplate with my fingertips.
Old 07-25-2012, 09:54 PM   #28
JS12
Thanks for the pic of the plastic cover. I'm actually going through the install now and was wondering how I tell which pin is pin 1 vs pin 2 on the temp sensors? I didn't see any markings distinguishing them.
Thanks!
Sent from my Nexus 7 using Tapatalk 2
