Old 08-04-2012, 03:46 PM   #43
flyguy27
flyguy27's Avatar
Drives: 2013 328i Sport line
Originally Posted by eduardot View Post
I've been wondering about this too. Maybe it's because of the auto recirculation?
Sent using Tapatalk
I dunno but my temp knob sits at about 2 o clock and its summer, so I dunno man but im not complaining.
Stock with Style
OEM FRONTLIP SPOILER|LED INTERIOR LIGHTS|RED FOOTWELL LIGHTS|GTI SEAT INSERTS|GTI DOOR SILLS|OEM LED CHERRY TAILS|REVERSE CAMERA|SEAT DRAWERS|RNS 510|
flyguy27 is offline   Reply With Quote
Old 08-04-2012, 05:10 PM   #44
reelknead1
Drives: 2010 CSG GTI
I would like to know how this effects the temp that the AC blows. I have a 2010 GTI which came stock with Climatic. My Girlfriend just bought a 2012 with manual and her AC sucks compared to mine. I have to set it to AC max and 4 speed to get it to cool down and the air that it blows still isnt that cold, if I put mine to 60 it freezes my hands on the steering wheel.
reelknead1 is offline   Reply With Quote
Old 08-04-2012, 06:36 PM   #45
tmiw
tmiw's Avatar
Drives: 2012 GTI 4dr Autobahn w/DSG
Send a message via AIM to tmiw
Parts ordered. Bought a Climatic control panel that came from a 2010 Jetta (which should arrive Tuesday), and waiting for the sensor and everything else to ship from 1stvwparts.
What gauge wire have you all been using? I know it doesn't matter, but the speaker wire that I have is pretty heavy gauge and probably won't be a good idea to put in the car.
2012 Candy White GTI w/Autobahn and DSG (Journal thread)
Tons of stuff.
tmiw is offline   Reply With Quote
Old 08-05-2012, 12:44 AM   #46
flyguy27
flyguy27's Avatar
I used 18 gauge.
Stock with Style
Old 08-05-2012, 09:17 PM   #47
heff3rd
heff3rd's Avatar
Drives: 2011 GTI Autobahn DSG Tornado Red
My girlfriend has a 2010 TDI and I can confirm that there's a sensor in the dash housing above the fuse panel, however I can not locate any sensor in the below dash housing (by the way her's is also held up by a zip tie.) I checked the passenger side area after removing the uder dash trim and didn't see the sensor there either. I'm wondering where else it could be located so we can confirm the proper location for this retrofit.
Also, instead of splicing wires isn't there a way to determine the correct VW trigger wire (such as what's been used for the euro dash headlamp switch, etc.)?
Any input from VW techs?
heff3rd is offline   Reply With Quote
Old 08-05-2012, 09:25 PM   #48
eduardot
eduardot's Avatar
Drives: '12 GTI
I believe they are all called repair wires. It just happens to be that the one used for the light switch is long enough for that application.
eduardot is offline   Reply With Quote
Old 08-06-2012, 07:31 PM   #49
UTmtnbiker
Is it possible to go less cold on the air?
Just did the swap myself, and all sensors are reading correctly, but on max cold, it just doesn't seem to be blowing out air as cold as it did before...almost a mildly cold air as opposed to arctic cold.
Wondering if I maybe didn't do the dial part correctly (can't remember now) and if it can be fixed via VAGCOM, as I have access to one.
UTmtnbiker is offline   Reply With Quote
Old 08-07-2012, 01:11 AM   #50
flyguy27
flyguy27's Avatar
Did you use vag after the install to monitor the temps the sensors or reading? Do this to confirm that it is blowing cold.
Stock with Style
Old 08-07-2012, 01:52 AM   #51
tmiw
tmiw's Avatar
Could go the T-tap route (although some people hate those). There only seems to be one shared wire to worry about, so it should be okay.
Tons of stuff.
Old 08-13-2012, 06:12 PM   #52
flyguy27
flyguy27's Avatar
Today I removed the panel on the passenger side similar to the fuse access panel on the driver side and there is also a rubber plug in the vent slot which means you could technically mount the temp sensor on passenger side in stead of the driver. Just a FYI.
Stock with Style
Old 08-16-2012, 10:51 PM   #53
tmiw
tmiw's Avatar
Ugh, I finally got all the parts in the mail and I find out that 1stvwparts only mailed me one housing, not two. Will have to wait on installing this till next week, I suppose.
BTW, is there any particular reason why I can't ground to a metal screw instead of tapping into the shared ground wire? Just curious.
Tons of stuff.
Old 08-17-2012, 01:54 AM   #54
tmiw
tmiw's Avatar
Anyway, decided to partially install it, even if I can't wire up the footwell sensor right now. Looks like it throws a soft code in VCDS if there's no footwell sensor, but still seems to work. Maybe it's using the value of another sensor in its place? (It's also possible it's behaving in a fully manual mode because of that code, but without further documentation on the Climatic system I can't be sure.)
It also doesn't seem strictly necessary to have the controls in the same position when swapping the control unit out, but I did the flap adaptation in VCDS just in case.
Tons of stuff.
Old 08-21-2012, 02:10 AM   #55
tmiw
tmiw's Avatar
Got the footwell sensor installed. Went ahead and followed the instructions at http://wiki.ross-tech.com/wiki/index..._(5K)_Climatic afterward and no problems so far. It did seem to turn on the heater when it was close to 72 degrees (where I had the dial set at) and kept it on even after it past that point, though. Is that normal?
BTW, I'm using a module that came from a totaled 2010 Jetta, so I'm not sure if that makes a difference:
Code:
Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   Shop #: WSC 00066 000 00146
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_Climatic_VW36.rod
   VCID: 38750A52838AE1D8D95
No fault code found.
Tons of stuff.
Old 08-21-2012, 09:22 AM   #56
eduardot
eduardot's Avatar
Drives: '12 GTI
I keep mine around 72-74, but it's really hot here. The heater has never turned on.
Mine also came from a 2010 Jetta. Slightly different part number and software. I don't think it would make a big difference.
Code:
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00149
   ASAM Dataset: EV_Climatic A01005
   VCID: 75CF3E92D49096B0023
