Old 10-08-2014, 02:08 AM   #113
Injen1us
Injen1us's Avatar
Drives: MK6 gti
Originally Posted by valj View Post
Great work! Vagmotorshop.ru here in Moscow has performed 3 similar AWD transplants recently, with the entire process being entirely plug-and-play except cutting off the niche for the spare wheel in the boot. Their K04 cars are demonstrating 0-100 km/h times of 3.8 sec.
They are also integrating the mk6 gti with the S-tronic 7 speed tranny from the RS3 which sustains massive torque levels.
Badass
2800lb k04'd daily driver
Radical Edward
Old 10-08-2014, 07:32 AM   #114
U-20T
Drives: BT GTI4Motion
Originally Posted by TwistedGTI View Post
Will we get a wiring diagram for the haldex and double fuel pump?
I will not be posting, it isnt too many wires though total 9. The harness above is the awd one.
You do need to cut and weld the floor plus add the awd brackets and wire it. not hard but not plug and play as may would think here on this forum, I dont want to get anyone too excited here. also need the trans.
USA gets the shaft on a few things overseas AWD manual is common in the 02q flavor (USA only golf R) and you can get the DQ500 where we don't have one. Would have used that instead, if i break it i guys i will have to think about importing one.
If I wasnt converting to dsg it would be easier.
Old 10-08-2014, 02:21 PM   #115
U-20T
MORE PARTS!!!!!
Only the good stuff - Wavetrac from Autotech
Old 10-08-2014, 02:27 PM   #116
lilfleck
Drives: '11 GTI Autobahn, DSG
Pretty sweet stuff. If you have the DSG trans cracked open (or when you do), could you post pics of what it looks like in there and how involved it is to install the wavetrack and new clutchpacks? I'm curious as to why the labor is so intense on DSG.
Old 10-08-2014, 04:08 PM   #117
Tom@APTuning
GolfMK6 Official Vendor
Tom@APTuning's Avatar
Drives: 2010 GTI S3+, 2012 Golf R S3
Internally they are very similar to the the 6spd manual, just more work to get to the internals and more parts/seals needed then a manual once they are opened.
Tom@APTuning is offline   Reply With Quote
Old 10-08-2014, 09:13 PM   #118
VanDorin91
VanDorin91's Avatar
Drives: '12 Candy White DSG GTI
This build is coming together and looking great! Cant wait to see whats next. Keep up the hard work.
Instagram: Vandorin_91
Jeremy Clarkson - "This car is more fun than the entire French Air Force crashing into a fireworks factory"
VanDorin91 is offline   Reply With Quote
Old 10-09-2014, 08:30 PM   #119
TwistedGTI
Drives: 2010 GTI 6 Speed
Originally Posted by U-20T View Post
I will not be posting, it isnt too many wires though total 9. The harness above is the awd.
May I ask why? It would help others who want to do this and eliminate any potential issues for the next person...
2010 CSG 6MT GTI
Revo Stage One, Black Beat Intake, Custom CBE, S3 Shifter with shortened shaft, Forge DV Spacer, Blacked out front emblems
Originally Posted by Aries Pope View Post
it's kind of like measuring your dick with silly putty.
TwistedGTI is offline   Reply With Quote
Old 10-10-2014, 08:37 AM   #120
U-20T
You need to wire it correctly, to put it simple. There are slight variations throughout cars and models so I am not putting it out there. Wire it wrong and you can say goodbye to a bunch of expensive electronics. Not going to happen from me, if someone wants to do it they will figure it out.
Old 10-10-2014, 08:40 AM   #121
U-20T
Like Tom said they are very similar (DSG-6MT), it basically looks like a manual with hydraulics and some sensors.
Cost is more labor, more to take apart and its also heavier. You also need to replace some parts when opening when you don't do with a manual.
Old 10-10-2014, 08:41 AM   #122
vwgti2.0t
Drives: 2011 CW GTI
Harness work - one of a few... using oem style harness tape and twisting for data, do it right or don't do it at all.
Twisting for data? I've always used the drill trick to twist wires together just to keep everything looking nice. But their is something with data behind it also? Never knew!
Either way, good shit man!
Old 10-10-2014, 08:47 AM   #123
U-20T
Data is twisted to help with interference/noise, all cat5/6 is like that too.
Old 10-10-2014, 08:57 AM   #124
U-20T
Compiling a few photos of the trans build, this is an AWD 02E -
Before build -
Opening up - Note there is more oil than you could ever think possible still in the trans even after you drain it.
Manual trans out -
Limited Slip Diff - Yes Wavetrac is the best, put that power to the ground.
Getting some paint and getting ready to install
Waiting on a few parts still and this oem style cooler will not be used.
Old 10-10-2014, 09:02 AM   #125
vwgti2.0t
Drives: 2011 CW GTI
Gotcha, that makes sense. I have noticed this with ethernet cable as well. Learn something new everyday!
Old 10-10-2014, 10:48 AM   #126
Tom@APTuning
My teachers would be mad for not remember exactly why but twisting it makes it less likely for electrical interference or something like that.
awd swap, big money, big turbo, mk6 gti, u-20t, unitronic
