I just ordered a 4dr white mkvi, and am looking at ordering velocity vb3's when delivery gets closer. Are there any reasons not to put 19's on the car? I have never had a wheel that large and wonder if anyone has had problems w/ rubbing or other problems.
You should have no problems with the 19" wheels as long as you fit the proper tyres and the car is not lower too much otherwise you will have rubbing happening.
I found a good post in the MKV forum http://www.golfmkv.com/forums/showthread.php?t=59761 which tell you what are the best combinations of tyres, wheels and how much you can lower the car with out having any problems.
Tires heavier wheels are harder to spin up and slow down. Robs power and performance.
Couple drawbacks.
1. cost of rubber
2. harsher ride
3. increased unsprung weight.
Tires get more expensive the bigger the wheel side.
Smaller sidewall means stiffer sidewall which of course means the car rides stiffer and harsher. You just THOUGHT that pot hole was bad... try it with a bigger rim try not to chip your teeth
