today on the hwy i did some vag com temp testing.
i wanted to see how good the OEM system is to see how important would the purchase of an oil cooler would be.
also, i wanted to have a baseline of the oem system on the NA car.
the test was simple: on a 93F day
-20 mins of miami traffic (stop and go) [heat soak]
-20 mins of 2.4k RPMs (6th gear) [baseline on normal operation]
-mins of 3.8k rpms (4th gear) [temp test]
-mins of 5.0k RPM (3rd gear) [high temp test]
-10 mins of 5.0K RPM (1st gear) [low speed high temps]
RESULTS
OIL:
Despite my attemps to overheat the oil, and to test the capabilities of the heat sink, results were impressive: The oil temp was fairly constant. Regardless of iddle in traffic, or any condition i threw, temp was always: 100-110C
Coolant:
looks like the oem radiator is easy to heat soak. On miami traffic the temp rose up to 96C, which was the highest (10 mins not moving).
While moving, at any RPM the coolant maintained its cool at 90-92 C.
The only danger i see so far is the coolant. with the right conditions, the oem system can be "beaten".
Fuel:
Despite my efforts, and a wide range of RPMs, and some wot runs showed no timing pull on any cylinder.
this is great.
AFR too was always on point.
This means that the fuel looks good, the O2 sensors arent faulty, spark plugs and coil packs are working as they should, knock sensors are doing their jobs and injectors arent dirty.
Ambient temp:
Weather for today was sunny (as always in miami) at at 32C with humidity at 60%
Conclusion:
Everything is perfect. Oil analysis shows perfect results as well. All ready for the turbo.
3rd gear
4th Gear
6th gear
