So im a new Owner to a Manual '14 GTI (Wolfsburg) and I had a few questions. I've done some extensive researching on the issues these car's have had. And would basically just like some clarification on them.
Thank you ahead of time!
1. Stock Clutches, I know they are weak (or have a weak pressure plate). But if Im only planning on doing some very light mods (Exhaust, maybe CAI) is this an issue I should expect to run into? Im new to driving a stick however I don't lay on the clutch, or do any uneccesarily hard shifting. Or is this more a problem with Stage I/II peeps?
2. Timing Chain Tensioner, this is the big-one I suppose. Since it can cause so much damage. I know a TSB exists for it, but it says 2008-2012(or 2013?) I believe. Do the 14's for sure have the updated part? Also.....was this ever a "major" issue (as in very common)? Or are we still unsure of the total number of faults? I know they went through a revised part (or was it two?) but has anyone I guess had any issues with the new tensioner? or new model cars with the updated tensioner installed?
edit: TB-15-12-01 is the TSB for it, it says 2008-2013 (But the TSB was released in 2012), so I don't know if mine has the new tensioner or not.
3. Water Pump? Is this even a common issue?, i've seen spats of mentionings of it failing, but nothing really set in stone?
4. I've seen Problems about people getting their intake manifold replaced? But I have no idea why? Im not even sure what the problem is or what years it applies to?
Is there any other probable/common repairs I might see? The Waste gate rattle is such a small issue ill deal with it if I hear it, but I can't think of anything else? I've heard The timing chain design, INA adjuster, bearing bridge with oil solenoids? But literally only seen them mentioned like once....
I know this "car" doesn't need to broken in thanks to the FAQ (See I Searched!) ahah, so i'll avoid mentioning that.
Side Question: How reliable are the turbo's themselves on the car? Thanks!:w00t:
I look forward to being a part of this community. It's by far the funnest car i've ever driven.
