3D Printer & C.A.D. Thread
AzteCypher
That's pretty cool. I might try printing that in ABS as I don't have an ASA.
GolNat
Those look great!!
I love printing in PETG not sure what issues you were having. Prints like PLA just stickier.
yakboyslim
Those look great!!
It might just be this Inland PETG+. For me it is so sticky that it will always string, but the bigger issue is that I have to run really low accelerations (or turn off pressure advance) or I get extruder skipping on every acceleration and unretract. Only filament that gives me that problem. It will be bad enough that layers with lots of retracts can end up underextruded.
I've messed with temps, speeds, accels, pressure advance, retract/unretract distance/speeds... I eventually decided this was good enough for a part that goes on the bottom of my car, hit print, and plan to never use it again.
I printed my diveplane/foglight flare pieces in ASA with no issue and much better surface finish - and faster. So at least for me, no reason to use PETG now that I used up what I had.
yakboyslim
Foglight flares / diveplanes. Printed in ASA and then vapor smoothed. Really happy with the finish. It's not perfect, with some visible layer lines on overhangs, but im happy with it considering zero sanding.
GolNat
One of the managers at work is really into RC cars. He wrecked one of his cars into a curb and broke some suspension components. Hobby shop told him parts were not available because the car is 7+ years old. He remembered I do 3D printing and asked if I could make him a replacement. Made him a "test" piece and he said it fit great. Charged him $10 dollars. I'm curious how it holds up. Used PETG. Not an exact replica but close enough. Those cylinders on the end hold the front suspension and are at a 3 degree angle. Can probably run different angles to change the drivability.
Broken piece. I forgot to get a shot of the printed version.
GolNat
