hi, i have golf 6 variant 2.0 tdi
i have a very strange problem with airbag sensor on left rear side
i have this fault code (B101804) only when i make hard turn on left side on higher speed, but it wont popup if i drive slowly, i had a feeling that some cable is in stress when i make hard left turn
and after ingnition cycle its shows me that its intermittent error, i also tried opening and checking the sensor that it didnt had any play or stress or damaged, but sensor looks good for me from outside
and i have obd11 and i checked scanner connected to obd2 port while driving and when i make the turn(left side) airbag error pops up, and then the fault code was static , and i read alot of information on google search they suggust to check the wiring and wire is located under the still trim and i didnt checked it
could someone guide me what would be the problem or reason for this kind of problem
