Desert MVIGTI
Ordered Hotchkis Sway Bars and DG Springs (And the outlandishly priced Tyrol Rigid Collar Subframe Kit.....Grambles if I find out you are on the take from Tyrol you are going to owe be drinks next time I am in the Redneck Riviera). I am keeping the stock dampers, for now....7200 miles on the car. Stock Detroits/all seasons.
They will be installed 12/22...this has been done before my many prominent senators on this site such as Grambles and Modshack....
Grambles, are you still running front soft, rear medium? Steve, what say ye?
And anyone else with the DG Springs/APR/Hotchkis Sway bar setup SPECIFICALLY. Not looking for a discussion about other anti-sway brands with the DGs......
Also, if you are running DIFFERENT dampers with the DG/APR/Hotchkiss bar setup, interested in hearing if the damper change caused you to alter your adjustable sway setting.
Bottom Line: Going to go soft front, medium rear to start unless someone says "no, brah, that's crazy....and here's why".....with a good story...
Both these products have been reviewed ad nauseum on this site...
Again...trying to keep this thread limited to a discussion of the various settings with APR/Hotchkis sway bars, DG springs, and whatever you are running for dampers.
