Arin@APR
GOLFMK7 Official Sponsor
APR is pleased to present the ultimate Oil Catch Can System for the MK6 Golf R!
Product Page: [ link removed per the rules ]
The APR Oil Catch Can System replaces the failure prone factory positive crank ventilation (PCV) system and traps excessive crankcase oil vapors and gunk from entering the engine. The system eliminates a common performance robbing boost leak, while reducing carbon buildup on intake valves, octane lowering oil vapors and oil pooling within the intake tract. It’s a simple modification to install, drains in seconds with the flick of a knob, and is recommended at all stages of performance.
Quick Facts
The Problems
An engine produces extreme pressures within its cylinders during operation and some ultimately slips by the piston rings and pressurizes the engine’s crankcase. This is exacerbated when increasing horsepower and driving harder. To relieve the pressure, the engine uses a failure prone PCV system that dumps the pressure, along with oil vapors, back into the intake tract to be consumed by the engine. Unfortunately, this results in the following performance robbing scenarios:
The Solution
The APR Oil Catch Can System eliminates the factory PCV valve with a billet-aluminum block-off plate. The plate routes crankcase gasses through the APR catch can, which filters oil vapors through a track-proven four-staged baffling system. The vapors pool in the bottom of the can, while the rest of the pressure is diverted back to the intake tract where it’s burned off by the engine.
The result is simple:
System Overview
More Photos
North American Kit Installed
ROW Kit Installed
REQUIREMENT NOTES: The manifold PCV port must be blocked off to use this product. This can be accomplished with the APR boost tap. Also, the system is only designed for use without the factory engine cover installed.
Application Guide
MS100124 - North American Golf R - [ Price removed per the rules ]
MS100117 - Rest of World Golf R - [ Price removed per the rules ]
Quick Facts
- Increases performance - Increases performance by eliminating a common boost leak, and reducing octane lowering oil vapors and airflow restricting carbon buildup.
- Eliminates a boost leak - The PCV block-off plate eliminates the failure prone factory PCV valve.
- Catches oil and gunk - Oil and gunk pools in the can, not in the intercooler piping.
- Easy to drain - A simple knob allows the system to drain in seconds without any tools.
- Easy to install - Installs in minutes. The hoses pop right on without tools thanks to the OEM Norma fittings.
- Easy to maintain - Yearly maintenance is a snap thanks to the two-piece billet design.
- High-quality hoses - Resist oil degradation, kinks, abrasion, and blockage from freezing, with an OEM look.
- High-quality can, plate and bracket - Strong, clean and attractive billet-aluminum and stainless steel parts look right at home in the engine bay.
The Problems
- Oil vapors mix with the air/fuel mixture, which reduces octane and hurts performance.
- Carbon builds up on the back of intake valves, which reduces airflow and hurts performance.
- Messy oil pools in the intake tract and coats the intercooler, leading to hose degradation, and reduced IC effectiveness.
- The factory PCV system can fail, creating a massive boost leak that directly pressurizes the crankcase.
The Solution
- A cleaner engine
- Better performance
- Elimination of a common failure point
System Overview
More Photos
ROW Kit Installed
Application Guide
