BigRobSA
I am at the shop, having a custom 3" turbo-back built from scratch (pics will be posted later on the other thread) and was also trying to have the ECU flashed, via OBDII, to upgrade to stage 2+. When hooked up, we got several instances where it didn't initialize the ECU (first stage of 7 in process). Then, after unplugging and restarting the process, we got up to the 6th stage of the process only to receive the same exact message "Failed to initialize ECU".
We verified a week and a half ago with tech support (after initially thinking it wouldn't work) that, once an ECU has had the removal/opening up/ground the solder joint/read-write process ran and completed, it is able to be updated via OBDII flash with the Cheetah cable. That is why we tried it that way.
Does anyone have any idea why we got that message and never got the one telling us to use the CPD?
:iono:
:iono:
