sauceman101
I can get pictures at some point this weekend. But has anyone had an excessive oil leak from the bottom backside of their vacuum pump on the head? Fixed a coolant line back there two weeks ago and found that my largest oil leak was the vacuum pump, the bottom back of the three mounting bolts was hand tight. When I put everything back together I torqued all three to spec (IIRC 9nm or ft-lbs, had the manual in front of me at the time). Now the leak I have coming from there is at least twice as large.
Not so much asking how to resolve this as I'll just pull the pump again and either replace the gasket a third time if tightening them a touch further doesn't resolve it, or add some of that great make a seal copper shit that works great on most things. Just curious if anyone else has had a decent leak from here or not. Doesn't appear to be at the cam cradle to head seal as I did that at the beginning of the summer and can see that the joint is oil less when the vacuum pump is off
